Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
Did you check the make morph target when exporting from poser?? Silly question I know but its the only thing I can think of. I see no reason they wouldn't work..
Senior MarketPlace Tester
If anyone sees a mind wandering aimlessly around..... It is mine.Â
I want it back.
I would try it but don't have Dina.. Kinda makes it a tad difficult... I honestly can't see why it won't work if you following the same procedure.. The principles should be the same..
I want it back.
I don't have ZBrush, so I can only give a couple of general suggestions. One, if you're exporting directly from the figure, make sure you only export the head (and not the tongue, too). Also make sure the "Weld Bodypart Seams" checkbox is NOT checked. As an alternative, you could import Dina's .obj file into Poser, spawn props with the group tool, and export the head body part from there. Also, I don't know about ZBrush, but some 3D apps will triangulate meshes, which will ruin the morph for sure. It might be something to check anyway.
This is really strange. I can't get it to work no matter what. The only thing I have checked when I export the head is "as morph target". I'm not exporting the eyes or the tongue. I'm doing everything exactly the same way as I did with Mike and it just keeps giving me the "target geometry has the wrong amount of vertices" -error. I'm puzzled.
I wish I could be more help but since I don't have ZBrush I can't try it myself. Do you have any other apps that can manipulate geometry? I was just thinking you could try making a morph with something else, even if it's just a garbage morph, just to test the process. That might tell you if it's a ZBrush problem or something else. I'm glad you like her knees and elbows. We spent a lot of time on those.
Once happened to me using Judy in P5. The problem was in Poser when I clicked spawn props didnt spawn correctly. Before spawn the head make sure to click Remove all from the grouping tool and then make sure the head is separate from the eyes using the X dials. Other thing, when importing back to Poser to spawn the prop remember to check flip normals and the rest remains unchecked. Royuriel
I just got my Dina... and I wanted to try to make some morphs for her right away. However, I get the "wrong amount of vertices"-error when I try to apply the morph to her head. I've made Michael morphs the same way, so I don't understand what I'm doing wrong. Anyone have any idea?
