Sat, Feb 8, 2:01 PM CST
Subject: How to Get Area Lights to Not Show in Reflections?
acrionx ( ) posted Sat, 13 May 2017 at 5:19 PM · edited Sat, 08 February 2025 at 9:49 AM
I have a room with big glass windows on 3 sides. I am lighting the room with 3 area lights, one for each window the same size as each window. In the material room, I added a Reflect node to the Alternate Diffuse input for the material for the window glass. When I render, I see the big white area lights in the reflections rather than what is outside. Is there a way to make the area lights not appear in the reflections but still light the room? I am using EZDome and I am using the area lights rather than the EZOuter prop to light the room because I find that Superfly renders much faster and less grainy that way.
www.acrionx.com | My Freebies | My Store | My Youtube Channel
Boni ( ) posted Sat, 13 May 2017 at 7:42 PM
Online Now!
Bad news is ... you can;t keep the area lights from showing in reflection. It is in the nature of a physical based render engine. Infinite lights are the only ones that don't reflect. The only way around is to use mesh based light ... or a different light set-up.
Boni
Boni ( ) posted Sat, 13 May 2017 at 7:45 PM
Online Now!
I do suggest a very bright infinite light (300 - 500) outside your Windows. I use this a lot, saves render time and graininess as well. I hope this helps.
Boni
acrionx ( ) posted Sun, 14 May 2017 at 4:10 AM
Thank you Boni. I'll try that.
acrionx ( ) posted Mon, 15 May 2017 at 8:15 PM · edited Mon, 15 May 2017 at 8:28 PM
We need portal functionality in Poser
https://www.youtube.com/watch?v=oveSskhIEAc
hornet3d ( ) posted Wed, 17 May 2017 at 5:17 AM · edited Wed, 17 May 2017 at 5:17 AM
acrionx posted at 11:17AM Wed, 17 May 2017 - #4305332
Very clever and very interesting, thank you for the link.
