Mon, Oct 21, 10:33 PM CDT
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Looking at each point in geometry mesh
Anthony Appleyard ( ) posted Wed, 24 May 2017 at 12:19 AM · edited Fri, 06 September 2024 at 5:35 AM
If I call a Poser Python script on a model, how could the script look at any one of the mesh vertexes and find (1) that vertex's unposed original coordinates as was in the mesh file, and also (2) where Poser posing has moved that vertex to? I may need both at the same time, for a project that I have in mind.
PhilC ( ) posted Wed, 24 May 2017 at 1:30 AM
geometry = poser.Scene().CurrentActor().Geometry()
geometry.Vertex(index) Returns the local space Poser vertex object with the designated index.
geometry.WorldVertex(index) Returns a world space vertex object by specifying its index. If no world space data is available, the function will return None.
Anthony Appleyard ( ) posted Wed, 24 May 2017 at 3:37 AM · edited Wed, 24 May 2017 at 3:42 AM
Thanks.
If I call geometry.Vertex(i) on point i and it yields (x,y,z), how on my Poser run's stage could the script move that vertex to position (u,v,w) ?
Would thus moving a vertex, automatically also update that vertex's stored geometry.WorldVertex(index) value?
Allstereo ( ) posted Wed, 24 May 2017 at 4:47 AM
Hello Anthony,
As a basis for writing your script, you can use my script Vertex Viewer Python Script to be found in the free stuff section. The link is: Vertex Viewer script
Allstereo
PhilC ( ) posted Wed, 24 May 2017 at 7:14 AM
Once you have defined the vertex you can use its Set method to change its position.
vertex.SetX(value) Sets the X coordinate of the vertex to the value given.
Suggest checking its WorldVertex before and after making a change to see if that updates. I'm pretty sure that it does.
