Wed, Nov 27, 1:38 AM CST
Renderosity Forums / Virtual World Dynamics
Welcome to the Virtual World Dynamics Forum
Virtual World Dynamics F.A.Q (Last Updated: 2024 Nov 26 4:26 pm)
Subject: Converting VWD Sim to Morph
ebergerly ( ) posted Mon, 19 June 2017 at 5:00 PM · edited Tue, 26 November 2024 at 11:42 PM
Is it possible to convert the results of a VWD cloth sim to a morph for the same conforming clothing? For example, if I fit some clothing to a G3, then use VWD to do a cloth sim, the result is an "xxxx_VWD" object. Can I then take that "xxxx_VWD" object and make it a morph of the original conforming clothing? I assume that you can't subdivide the cloth in VWD or else the vertices won't match for the morph? And you can't apply a Smoothing Modifier in D|S after you generate the "xxxx_VWD" object (which I like to do to smooth the results)?
Thanks.
ebergerly ( ) posted Mon, 19 June 2017 at 6:09 PM
Hey, I did it !!!!!!!! Don't ask me what settings I used, I had to try it like 3 times.
Now just to reproduce it :)
ebergerly ( ) posted Mon, 19 June 2017 at 7:17 PM
Well, I think it's really straight forward if anyone's interested. Do the sim, which generates the _VWD clothing object. Hide everything in the scene but that VWD object, and export as OBJ. Use the default (?) DAZ Studio settings for the OBJ.
Now select the original conforming clothing and open Morph Loader Pro. Select to convert From Daz Studio, and then under Choose Morph Files find the OBJ you just saved with the _VWD object, and then use the defaul settings, and click Accept.
That should put a morph dial under Parameters/Morphs/Morph Loader.
Cool.
itou31 ( ) posted Tue, 20 June 2017 at 2:22 AM
Thanks for the tips !
VirtualWorldDynamics ( ) posted Tue, 20 June 2017 at 3:23 PM
@ebergerly : Thank you for this info. It will certainly interest a lot of people.
____________________________________________
Follow me on Twitter : @VWDynamics
Watch demo videos on Youtube
