Don't know if there's a script but you can edit the Cr2 using Cr2Editor, which is free and very good. A search and replace on Sensitivity should do the trick.
You can open props in a text editor and do the same thing there.
BTW, I notice you have a child with autism. Me too. :)
Not a bad idea, but still a little more labor intensive than I'd like. I may have to brush off my python skills shudder and see if I can manage it myself.
And autistic kids are au-some, lol! :)
Intel Core i7-8700 6-Core 3.2 GHz (4.6 GHz Turbo), 32GB RAM, two GeForce GTX 1080 Ti GPUs
DS 4.10, Photoshop CC and CS6, Poser 11 Pro, Vue 2016, CarraraPro 64bit, Autodesk Inventor, Mudbox, and 3DS Max
One in 68 children is diagnosed with autism. One is mine. ♥
Snarlygribbly's Scene Fixer python script - http://orphans.basicwiz.com/
When you run it - select the second option - Dials - then select all the dials you want to change the sensitivity on - input the new sensitivity value - tick the box and click apply.
all done - rerun the script to reverse the settings
There are so many times when I need very fine adjustments to the X-Y-Z translate, rotate and scale dials, and it makes me crazy to have to change each dial's settings from a sensitivity of 1 to 0.1 for EVERY dial on EVERY prop or figure that needs fine adjustment. Any python wizards out there who could make a script that changes these dials' sensitivity with one click per prop? In a time when I use V4 items FREQUENTLY on figures like Pauline or Dawn, I'm running into this issue all the time and it's a huge workflow speedbump. Without that change in sensitivity, a tiny bump of the dial moves the prop WAY too far. If a product that does this already exists, please point the way!
