thank you all
Maybe I'm unable to find HDRs images
But if I need a panorama out of the window (for example, a high floor of a skyscraper) I do not find pictures that can fit well, maybe I'm looking for in some unsuitable archives, but I find only exterior views.
One of the few usable is BarcelonaRoofTops or Helipad_Afternoon from sIBL Archive but nothing else
Here is an exsample in low resolution, but nothing with a slyline from a high skyscraper window.
This one with high resolution from another camera.
Poser Pro 2014 SR 1 on Windows 7 64
bit
I use IDL, Gamma Correction and EZSkin for all
final renders.
Hello all,
Because it appears not easy to find the appropriate image, perhaps you can rely of jpg format of equirectangular images. Here it a Flicker group with many many equirectangular images. These image can be used with a skydome prop. The resolution is not high as HDR but can be useful Flicker group
Allstereo
I will point out and hope that the right section is where to ask.
I'm interested in purchasing this product (Product) but before spending money I would like to find an appropriate view (similar to rendering) in HDR format (Or other format that can produce light)
Suggestions about it?
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
