Wed, Jan 8, 3:07 AM CST
Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Jan 05 8:10 pm)
Check out the
Subject: Silo 2.5 Released
LuxXeon ( ) posted Wed, 23 August 2017 at 4:21 PM ยท edited Thu, 02 January 2025 at 2:12 AM
Looks like NeverCenter has finally released a new update to their Silo modeling package. I'm sure users of this modeling software will wish to take a look.
http://nevercenter.com/silo/
Some updates and improvements include:
  • Collada and FBX format support (import and export).
  • Completely updated, modern, cleaner interface styling.
  • Simplified Button Settings editor for easier custom setup design.
  • Updated drawing code with in-app anti-aliasing setting.
  • Added menu item to reveal custom primitives folder.
  • Custom primitives folder can now include nested directories.
  • Newly loaded files are now automatically framed in the viewport.
  • New presets for color settings.
  • Updated presets for mouse settings.
  • Various other interface streamlining and improvements.
  • Fixed bug some users experienced with selection when anti-aliasing was enabled.
  • FACT file import/export bug fixes.
  • STL file import/export bug fixes.
  • Fixed some tools reverting to the wrong manipulator.
  • Fixed some manipulators allowing incorrect selections.
  • Many error messages moved to pop-ups to make it more apparent when something goes wrong.
  • Images always saved with correct extension even when missing from file name entered.
  • Improved many error messages for clarity.
  • Moved to 64-bit-only on Windows, greatly reducing crashes.
  • Added menu item to reveal preferences folder.
  • Object properties window now always shows shape properties (in addition to component properties).
  • Texture seam display is now per-object.
  • Texture seams can now be marked using highlighted edges.
  • Cleaned up internal code.
  • New app icon.
  • Lots of other bug fixes.
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook:ย https://www.facebook.com/luxxeon
Lobo3433 ( ) posted Wed, 23 August 2017 at 4:44 PM
Forum Moderator
Nevercenter has released several new short tutorial more like new feature in action on their Youtube channel can be found Here
Lobo3433
Blender Maya & 3D Forum Moderatorย
Renderosity Store
My Free Stuff
Facebook
Twitter
LuxXeon ( ) posted Thu, 24 August 2017 at 12:09 AM
Thanks, Lobo.
My Free Models
My Video Tutorials
My CG Animations
Miss B ( ) posted Thu, 24 August 2017 at 12:08 PM
Oh thanks for the link Lobo, as I'm sure it will come in handy. ๐Ÿ˜‰
_______________
Butterfly Dezignz
martial ( ) posted Thu, 31 August 2017 at 5:23 AM
I have Silo 2,4 .
Can i just install on it or i must uninstall last version before?
Thanks
Miss B ( ) posted Thu, 31 August 2017 at 11:54 AM
As a rule, I like to carefully install the new version separately. That way I can easily uninstall it if I'm having problems with it, and still have my previous version to work with. Then, if everything's working fine, I can uninstall the older version after moving whatever projects I've been working on to a location easily available from the new version.
This is just how I do things, but if you don't want to do that, I believe most software installation packages now-a-days are set up to install in place of whatever version you are currently running.
_______________
Butterfly Dezignz
martial ( ) posted Thu, 31 August 2017 at 12:25 PM
Thanks , miss B It is a good suggestion I have my serial number So i can separatly install Silo Hope the upgrade download is a full version
ShawnDriscoll ( ) posted Mon, 04 September 2017 at 11:20 PM
I just installed it (version 2.5.02). And loaded a simple OBJ into it.
Nada.
Not impressed with it so far. Hexagon and my other apps import the OBJ just fine. Will probably go back to Silo 2.3.1.
Khai-J-Bach ( ) posted Fri, 08 September 2017 at 5:28 AM
Loaded an obj just fine last night.. So not sure there shawn..
But, the collada I loaded direct from sketchup moved all the components I'd made to zero point... headscratch dunno if that's su or silo tho.....
Miss B ( ) posted Fri, 08 September 2017 at 12:11 PM ยท edited Fri, 08 September 2017 at 12:12 PM
ShawnDriscoll posted at 1:01PM Fri, 08 September 2017 - #4313547
Nada.
Hey Shawn, if you haven't uninstalled it, try something and see if it helps. I know whenever I import an OBJ into Silo 2.3, I always have to zoooooooom in pretty far, because it's usually a tiny little spec in my viewport. That may be what you're experiencing as well, but since you didn't see the OBJ front and center, you thought it might not be there at all.
_______________
Butterfly Dezignz
Miss B ( ) posted Fri, 08 September 2017 at 12:32 PM
OK, too late to edit my previous message, so here's another tidbit I found on another forum, and it works quicker than manually zooming in to see the object.
I usually have the Scene Editor window open, and if you select the newly-imported OBJ, then click somewhere in the viewport, Ctrl-F will frame the selected object, zooming in if the object is tiny. I just tried it, and it works well. ๐Ÿ˜‰
_______________
Butterfly Dezignz
ShawnDriscoll ( ) posted Fri, 08 September 2017 at 2:55 PM
It's just an OBJ of a scanned person. Nothing fancy. I imported the OBJ into Hexagon 1.21 and exported it out again. Then Silo 2.5.02 was able to import the model just fine.
Miss B ( ) posted Sat, 09 September 2017 at 10:29 AM
Ahhhh, glad you got it to work. ๐Ÿ™‚
_______________
Butterfly Dezignz
