Thu, Feb 20, 1:19 PM CST
Subject: Location of folder for NPR textures
kenmo ( ) posted Sat, 02 December 2017 at 11:02 AM ยท edited Wed, 19 February 2025 at 8:45 PM
Can anyone tell me where the textures are located for NPR renders?
When I go through the Vue menus for Render...
Render-->NPR Options--->Shader--->Texture
It gives me the following path:
First texture: "C:UsersadminDocumentse-on softwareVue xStream 2015"BitmapsNPRLevel01.jpg
Second texture "C:UsersadminDocumentse-on softwareVue xStream 2015BitmapsNPRLevel02.jpg"
Through to Ninth texture
However I can not find this path ""C:UsersadminDocumentse-on softwareVue xStream 2015BitmapsNPR" or a file named Level01.jpg or Level02.jpg ... or Level09.jpg
Also I have Vue Complete 2016 installed and not Vue xStream 2015 (never, ever owned xStream).
I'm curious what these Level0x.jpgs look like as I would love to attempt to create some of my own.
Any ideas?
Cheers
Ken
TheBryster ( ) posted Tue, 05 December 2017 at 9:35 AM
Simple things first. Do you have hidden folders visible?
If a search of your drive does not reveal the location of Level01.jpg I would suggest it does not exist.
kenmo ( ) posted Tue, 05 December 2017 at 10:03 AM
Hidden folders are turned off. I also ran Windows file explorer in Administrator mode.
Has anyone created any custom textures for Vue's NPR option?
ShawnDriscoll ( ) posted Tue, 05 December 2017 at 9:28 PM
Sometimes, my Photoshop will see image files that my Paint Shop Pro does not see. Depending on what app made the images and if it had full admin rights at the time.
kenmo ( ) posted Wed, 06 December 2017 at 6:17 AM
I'm not browsing via Photoshop. I am browsing via the Windows File Explorer and running File Explorer as Administrator.
ShawnDriscoll ( ) posted Wed, 06 December 2017 at 7:30 AM
kenmo posted at 4:26AM Wed, 06 December 2017 - #4319495
Yep. Me, too. That's why I been using my CS2 to browse folders lately where I have saved screen captures from video games. Since two Windows 10 updates ago, the OS has been hiding such files from me even with "show hidden files" turned on in Windows. CS2 shows my PNG and BMP files plain as day.
ShawnDriscoll ( ) posted Wed, 06 December 2017 at 8:09 AM
I did some hunting around. Windows 10 is now using a VirtualStore folder. It's been migrating my apps there for some reason. Found my files using Explorer now.
kenmo ( ) posted Tue, 12 December 2017 at 6:19 AM
I was looking for an UNC path? Do you know what it is?
ShawnDriscoll ( ) posted Tue, 12 December 2017 at 3:21 PM
If it's Windows 10, I'd unhide all folders and system files and start my search in Libraries. Than go from there. Your folders will be unmerged, and easier to find in a list of them.
kenmo ( ) posted Tue, 12 December 2017 at 3:55 PM
My files are all unhidden and I've also ran Windows File Explorer in Administrator mode. I find nothing.
ShawnDriscoll ( ) posted Tue, 12 December 2017 at 6:47 PM
Explorer won't find them. I don't know if Microsoft is going to change that or not. The UAC is a lost cause for them. So they are trying another way to keep users from seeing all their stuff. I was able to find all kinds of files on my drive using browsers from inside apps and going into my VirtualStore.
kenmo ( ) posted Tue, 12 December 2017 at 9:45 PM
And I'll ask again, what was the UNC to the NPR textures you found?
No need to repeat what you've already said. I get it. ๐Ÿ˜†
I've been employed as a network server admin for 30+ years. Windows Server 2008 through to 2016. In the past I supported Novell Netware ,Netware on Suse Linux and Citrix Winframe 1.4 as well as Windows NT 3.51 in the past.
ironsoul ( ) posted Fri, 15 December 2017 at 2:13 AM ยท edited Fri, 15 December 2017 at 2:15 AM
I've gone through my content and can find no NPR texture files, the entries are blank and the NPR folder does not contain any textures. Last patch I attempt to install was corrupted and failed which is not the first time with e-on. One thought is the install or update images were not built correctly. It would be interesting to know if anyone has NPR textures or if we are all missing them.
HartyBart ( ) posted Thu, 11 January 2018 at 2:29 PM
Running on Windiws 8.x, I see Vue 2016 NPR Styles presets at:
C:ProgramDatae-onsoftwareVue xStream 2016NPR StylesListed
And
C:UsersUSERNAMEAppDataRoaminge-on softwareVue xStream 2016ConfigCollectionsNPR Styles
Also empty folders for them at:
C:UsersUSERNAMEAppDataRoaminge-on softwareVue xStream 2016ConfigCollectionsActivationNPR Styles
And
C:UsersUSERNAMEAppDataRoaminge-on softwareVue xStream 2016ConfigSelection PresetsNPR Styles
However, no BitmapsNPRLevel02.jpg etc. Possibly they're being generated procedurally 'on-the-fly', according to the preset settings, and then wiped after the render completes?
