Sat, Jan 25, 12:39 PM CST
Subject: Export Import Poser to Bryce Problem
Kurgen ( ) posted Mon, 15 October 2001 at 8:39 AM ยท edited Sat, 25 January 2025 at 12:37 PM
Im haveing a problem when i export a object as 3ds from poser then try to import it to poser I get a 'bad media' error?? when I try it as a .obj it fails on importing as well, sometimes crashing Bryce. Ive tried the same thing with 2 diferant objects and the same thing. One is loaded to Poser as a Prop the other as a character. As there both doing the same thing Im pretty sure its something Im Doing or Not doing in the export process from poser, Using poser 4 updated and Bryce 4 updated. Any help much appriciated Im going bald from pulling my hair out LOL Thx :)
Kurgen ( ) posted Mon, 15 October 2001 at 8:42 AM
eek cnat find edit?? lol hmm getting tired time for bed hehe the top line should read.....'then try to import to Bryce'(not poser)
thgeisel ( ) posted Mon, 15 October 2001 at 9:45 AM
Bryce has a problem with importing large objekts.dont know what you want to import,but look at your exported file. if its bigger than about 12 mb it will you get an " out of memory error" if the file is smaller,load it in uvmapper and save it from uvmapper,sometimes that solves problems
Kayleb ( ) posted Mon, 15 October 2001 at 11:04 AM
Try saving them out in another format than .obj the .3ds works many times when .obj does not, and Bryce can read it.
X-perimentalman ( ) posted Mon, 15 October 2001 at 11:21 AM
I had this problem once before. I was importing 3DS files into a poser scene, and exporting the whole shooting match as as obj, and imported into bryce and it crashed. I exported everything one piece at a time until I found the culprit, it was a length of chain, left it out, and rebuilt the scene in bryce without it. Since then I discovered that I can get around this if i save any imported 3ds stuff to the poser library, before building the scene. If everything comes from the poser library I don't have this kind of problem exporting as an obj, even the length of chain that bollixed me up before.
Kayleb ( ) posted Mon, 15 October 2001 at 11:27 AM
I have found even after loading in a 3d item, saving it to poser library, that some items won't load into Bryce. Most of the time it is a prop.
black-canary ( ) posted Mon, 15 October 2001 at 1:45 PM
be sure you are importing with the import on the file menu, not the one on the object palette.
Ghostofmacbeth ( ) posted Mon, 15 October 2001 at 3:21 PM
Also it kind of deends on what the file is. There is a problem with the Vicki pants from Pro Pack. It works fine from normal poser. Every once in a while it is a texture that goofs it as well. Good luck
