Tue, Nov 26, 4:21 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Nov 17 7:07 pm)
banner
Subject: V4 weight maps
Fall_Guy ( ) posted Sun, 07 January 2018 at 10:40 AM · edited Sun, 24 November 2024 at 1:52 AM
Hi there,
Having downloaded and following the instructions for V4WM, .... I cannot find the under the Poser/Scripts Menu a category named Poseplace as outlined in the V4WM pdf. I have checked my installation : Poser 11 ContentRuntimePythonPoserPlace and the folder and file is there. Its just not showing up in my Poser/scripts menu. Been away from Poser for quite a while and have just ungraded to Poser V11.1 so I'm in the process of starting a fresh.
Any help or guidance would be much appreciated. (running windows 7/64)
Thanks
TrekkieGrrrl ( ) posted Sun, 07 January 2018 at 10:55 AM
Bearing in mind that I too have been away from Poser for ages ... I think you need to add the desired script to a button first? 💭
Jules53757 ( ) posted Sun, 07 January 2018 at 11:06 AM
Poserplace is the Folder that will be installed, if you download the V4WM and install it.
V4WM from PoserPlace is available, as far as I know, at renderotica but keep in mind that there is a lot of stuff that would violate the TOS of Renderosity, not only nudity.
Ulli
willshetterly ( ) posted Sun, 07 January 2018 at 11:08 AM
I haven't tried V4WM, but I just tried another V4 improved model, Sasha-16 and I'm very impressed. The instructions are easy to follow, and the changes smart. S-16 has features for erotic art that aren't relevant to many of us, but they can be turned off or simply ignored, of course.
donnena ( ) posted Sun, 07 January 2018 at 11:09 AM
There have been changes to Python over time. This means that older scripts may not run on Poser 9 and 10, Not all scripts that ran on Poser 10 work on Poser 11. That said, I don't know how to help you.
Andy!
Jules53757 ( ) posted Sun, 07 January 2018 at 11:33 AM
I just saw it, you installed the Python script under Poser Content. I t has to be in that directory where Poser is installed.
Ulli
hborre ( ) posted Sun, 07 January 2018 at 12:11 PM
Agree and verified. The script needs to be in the main Poser directory. @willshetterly: although SASHA-16 is a great addition to the V4 family and works quite well as a WM figure, it does not accept all V4 morph packages. It would be frustrating for a new user, or returning, user to figure out exactly what the problems are without reliable resources immediately available.
willshetterly ( ) posted Mon, 08 January 2018 at 1:17 AM
@hborre, thanks for the warning.
Fall_Guy ( ) posted Tue, 09 January 2018 at 9:51 AM
Hello,
Thanks for ALL the help and advice. Jules53757 I have now re-installed my poserplace folder into the following:
C:Program FilesSmith MicroPoser 11RuntimePythonposerScripts ............. (my main POSER installation)
However the folder is still not showing/available in my Poser 11.1 menu/scripts option.
I will probably un-install POSER 11.1 and try a re-installation to see if that solves the issue, and let you know how I get on. I'm pretty sure I have done everything the same as I did in Poser 2014 pro and it worked fine.
Many thanks again for your time.
Fall_Guy ( ) posted Tue, 09 January 2018 at 10:46 AM
Hi Everyone,
Ok, I've found some different V4WM documentation, which now clearly defines the location of the Poserplace folder. I had placed the Poserplace FOLDER into the poserScripts FOLDER,....... whereas the correct location for this folder is in the ScriptsMenu FOLDER.
For Poser 11.1 as below: C:Program FilesSmith MicroPoser 11RuntimePythonposerScriptsScriptsMenuPoserPlace
Now it appears in the Poser menu as expected.
Many thanks again for time and patience.
lonelybat1989 ( ) posted Wed, 17 January 2018 at 9:12 AM
I agree, Sasha 16 is an awesome solution to make V4 more modern. The only morphs that don't work well are the Creature Creator morphs. I recommend using here over the V4WM due to not having to convert clothing, but to each their own.
Eric Walters ( ) posted Sat, 12 January 2019 at 4:17 AM
I'm glad to see V4-WM is still available. I was heavily involved with beta testing back in the day. Went away for several years myself. Trekkigrlll (that's a name I recall from long ago).
mmitchell_houston ( ) posted Sun, 13 January 2019 at 5:28 AM
Eric Walters posted at 5:28AM Sun, 13 January 2019 - #4343507
That link didn't work for me. Could you test and repost?
System: Lenovo Legion Pro 7 16IRX9H Laptop | Windows 11 Professional | 32GB RAM |  14th Gen Intel® Core™ i9-14900HX | Nvidia RTX 4090 Laptop GPU 16GB 9728 CUDA Cores
mikemitchellonline.blogspot.com   |   Poser Noir Comics Tutorial   |   Illustrations Honored by Renderosity
ypvs ( ) posted Mon, 21 January 2019 at 6:25 PM · edited Mon, 21 January 2019 at 6:26 PM
mmitchell_houston posted at 12:25AM Tue, 22 January 2019 - #4343570
Try here
http://www.morphography.uk.vu/~cagepage/poserplace/poserplace.html
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
mmitchell_houston ( ) posted Tue, 22 January 2019 at 8:24 AM
ypvs posted at 8:23AM Tue, 22 January 2019 - #4343988
Try here
Thank you! That link does work for me. I'll download and install them tonight!
