Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
As far as I know, Poser still uses absolute sizes - pixels - which do not relate in any way to dpi. You'll have to do the necessary calculations to render an image for conversion to 300 dpi. For example, a 300 x 300 image will equate to 1 inch square - 25.4 mm - at 300 dpi. Work out your desired size in inches, multiply by 300, render at that size.
@SamTherapy, thanks for the tip.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Â
Not sure what you mean by flat lined. If you mean to put a toon line around an image then you would do this under Render>Settings:
To render at 300 DPI that would be under Render>Dimensions:
Hope this helps!
Well, how about that? Shows how long since I played with the render settings. I just render at "Bloody Enormous", then crop and resize as necessary.
Hi Sam! The resolution can be set in Render>Render Dimensions
The Render Settings is where you can select the toon outline
Glad this helps!
Thanks for everyone's help. Sorry I wasn't clear in what I was looking for. What I wanted was this. I set up a figure and set Display/Figure Style to "Flat Shaded Lined." That gave me:
What I wanted was to get the same effect in my render, a shaded white figure with a grid all over. Anyway I discovered the answer and it was ridiculously simple. In render settings I chose the "Preview" tab and the "Render Now (Firefly)" button turned into "Render Now (Preview)." Press the button and I got what I wanted.
If you want a true render, you can create a UV template (UVMapper is free for the regular version) and place that on your figure. The figure can then be used in any normally rendered scene.
@digitell - yep, I meant "Render Dimensions". I shouldn't type while talking to small children.
SamTherapy posted at 12:25PM Sun, 14 January 2018 - #4322209
@Sam - LOL...Quite understandable!
digitell posted at 9:14PM Sun, 14 January 2018 - #4322212
It goes something like this:
"Daddy, look at this picture I drew of Carmen (one of our cats) knocking over your guitar and can you tell Ilona to stop looking at me in that funny tone of voice and Mummy says if you don't move your toolbox she's going to shove it up your bottom and can I have an ice cream please?"
"Yes, that's lovely... WHAT!?"
"It goes something like this:
"Yes, that's lovely... WHAT!?""
OMG...that is sooo friggin hilarious!!!! And cute too!! Big Fun!!! LOL!! Sounds like you have a fun "Entertainment Center"! A good time was had by all!
I'm using Poser Pro 2014. How do I render a Flat Lined character in full resolution? When I use "Export image" it creates a screen resolution (72 dpi) image. Is there some option in Render Settings to export the Flat Lined character I see on the screen as a 300 dpi image for print?
