Tue, Jan 21, 11:52 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Subject: Oh, (insert profanity of choice here) Poser no workee. Boo hoo.
SamTherapy ( ) posted Fri, 19 January 2018 at 6:39 PM · edited Tue, 21 January 2025 at 11:43 PM
Since yesterday, my Poser Pro 2012 will not render. It crashed out during a "Calculating Subsurface Scattering" and since then, will do anything except render, even when SSS isn't selected. I cleared out the render cache, made my render size smaller, tried rendering a variety of different things, all with the same result. The render appears to begin, then Poser hangs and Windows gives me an ever so helpful message "Poser has stopped responding, nah nah nah... please go and boil your head", or similar.
Computer is a Win7 Professional 64 bit with 8GB Ram, Poser is Poser Pro 2012 64 bit. For the record, the 32 bit version does exactly the same.
Any advice?
Boni ( ) posted Fri, 19 January 2018 at 6:49 PM
Sounds like it could have gotten corrupted. You might want to reset the program ... Let me look up the process for you. Sorry you are going through this Sam.
Boni
Boni ( ) posted Fri, 19 January 2018 at 6:59 PM
The fixes I found referred to the UI and not render crashes. For that it could have to do with your graphics card ... check to see that is is working properly ... then, I'm afraid the two suggestions I have is to make a report to SM (they are very good about responding) or bypassing that and simply saving all your runtimes (rename the primary download runtime for your current Poser version with a new name) to a separate file ... then un-install and re-install Poser. Don't forget to look up your serial number, write it down and set it aside for the process. I wished I had a better solution for you.
Boni
SamTherapy ( ) posted Fri, 19 January 2018 at 7:14 PM
Many thanks, Boni. I think a new install may be the way to go. I'll hunt down my backup discs tomorrow.
Boni ( ) posted Fri, 19 January 2018 at 7:27 PM
My sympathies.
Boni
ThunderStone ( ) posted Fri, 19 January 2018 at 9:41 PM
Has Windows done an update recently? If so, you might want to re*install your graphic drivers.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Kazam561 ( ) posted Sat, 20 January 2018 at 12:03 AM
Or the flip side is check if your graphic card software updated. Also check the General Preferences in Poser. Are you trying to re-render a specific scene? It's possible that scene got corrupted when you saved it to your hard drive. Have you tried rendering different scenes?
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
Jules53757 ( ) posted Sat, 20 January 2018 at 3:04 AM
Did you try the old "trick", renaming the LibratyPrefs.xml to LibratyPrefs.bak and delete the Poser.ini?
Ulli
SamTherapy ( ) posted Sat, 20 January 2018 at 6:13 AM
Thanks for the suggestions, folks. I haven't tried any of the above... yet. Spent the morning hunting for my backups, to no avail, I might add. :(
Windows hadn't updated in the time period this problem happened, nor was it an old scene I was trying to re-render. Far as I can tell, the graphics card is working fine.
Before I do anything else, I'll try Jules' suggestion. If all else fails, I'll get on to SM and see how I go about getting a new download. If I can at least save my existing Runtimes, things won't be too bad.
SamTherapy ( ) posted Sat, 20 January 2018 at 6:59 AM
Ulli - you're a star! It worked perfectly. Just have to re-attach my old Runtimes and recreate me startup prefs but that's nowt to complain about.
Fantastic stuff, Sir! Many thanks. And thanks, also, to everyone else.
Khai-J-Bach ( ) posted Sat, 20 January 2018 at 9:24 AM
+++Divide By Cucumber Error. Please Reinstall Universe And Reboot +++
SamTherapy ( ) posted Sat, 20 January 2018 at 9:41 AM
Khai-J-Bach posted at 3:41PM Sat, 20 January 2018 - #4322612
