Sat, Feb 1, 9:47 AM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Parameters settings window
mdbruffy ( ) posted Thu, 11 January 2018 at 4:17 PM · edited Sun, 01 December 2024 at 4:56 AM
I use Poser 11. Usually, it doesn't give me any problems. BUT, almost every time I click on a dial- just a simple click- this freakin' window pops up. It's driving me crazy! Does anyone have ANY ideas how to shut the )*%$% thing off??!!
ypvs ( ) posted Mon, 15 January 2018 at 6:52 PM
The only way I can get it to pop up is with a double click. Dragging the wheel or using the arrows either side doesn't seem to trigger it. OS Mouse settings accidently set to give double click??
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
mdbruffy ( ) posted Mon, 22 January 2018 at 7:11 PM · edited Mon, 22 January 2018 at 7:12 PM
ypvs posted at 7:08PM Mon, 22 January 2018 - #4322312
Sorry it's taken so long to answer. The comp I use for the internet has been in the shop this past week. But to answer your question, I position the cursor, click once and that window pops up before I can do anything else. Sometimes I have to go through this several times before I can finally use the dial.
ypvs ( ) posted Tue, 23 January 2018 at 5:06 AM · edited Tue, 23 January 2018 at 5:07 AM
One option is to let Poser rebuild the Poser.ini and LibraryPrefs.xml file.
On a windows machine they are found in C: > Users > yourusenname > AppData > Roaming > Poser > 11. (not sure where on a Mac) You will have to make hidden files visible.
Copy and paste the files so you have a back-up then delete them. When you restart Poser you will have to re-add your runtimes, re-organize the windows back how you want them and add any other customizations.
Hope this helps
mdbruffy ( ) posted Tue, 23 January 2018 at 1:57 PM
Sounds like I'd be better off just re-installing the program .
TrekkieGrrrl ( ) posted Wed, 24 January 2018 at 5:00 PM
mdbruffy posted at 11:58PM Wed, 24 January 2018 - #4322847
That's kinda like chopping off your arm to cure a hangnail ;)
How old is your mouse? When mine starts to fail (the do get worn out) it usually starts by thinking I will doubleclick when I only clicks once.It might be something that simple :)
mdbruffy ( ) posted Wed, 24 January 2018 at 5:04 PM
TrekkieGrrrl posted at 5:02PM Wed, 24 January 2018 - #4322957
That's a possibility. My mouse is for a Genesis tablet and it is more than a few years old.
