Fri, Nov 22, 3:42 PM CST
Renderosity Forums / MarketPlace Customers
Welcome to the MarketPlace Customers Forum
Forum Moderators: tim, msansing, ebasham
MarketPlace Customers F.A.Q (Last Updated: 2024 Nov 20 10:28 am)
Contact and Support Information:
To reach our Marketplace staff, please open a support ticket at
support.renderosity.com
Our goal is to respond to support tickets within 24 hours, 7 days a week.
Subject: Downloaded zip installer can't extract files
SpottedKitty ( ) posted Thu, 08 March 2018 at 6:02 PM · edited Fri, 22 November 2024 at 3:36 PM
I have a problem with a purchase I made last night; three of the items extracted from the downloaded .zip with no problems, but the fourth is throwing out lots of errors.
It's the Wilbur Bridge for D|S — the downloaded file is 35.2MB, but what can be extracted comes to less than 1MB of mostly content thumbnails; no files in the data, documentation or textures folders.
I'm getting the same "unspecified" error using both WinRAR and the built-in Windows zip utility. I tried using the WinRAR repair tool, and it didn't work.
Any suggestions?
Miss B ( ) posted Thu, 08 March 2018 at 9:33 PM
That sounds like something got corrupted. I've never had a problem with a zip download from the Renderosity store.
Have you tried downloading a second time? Sometimes that works, because something occurred while downloading it the first time.
_______________
Butterfly Dezignz
SpottedKitty ( ) posted Thu, 08 March 2018 at 10:17 PM
I've tried re-downloading a third and fourth time, with identical results. It has to be a glitch with the .zip file I'm pulling down from the Renderosity servers.
I have had very occasional dud zips, but the last time was many years ago, and I was always able to fix them with the WinRAR repair tool. This seems to be something different. When I look inside the zip, I can see all the missing files, I just can't extract any of them.
Miss B ( ) posted Fri, 09 March 2018 at 12:42 AM
Oh that IS weird. The only times I've had problems with any zips I've download from any of the stores I shop at, I couldn't even look inside the zip, so it's unusual you can actually see the files, but can't extract them.
Have you tried getting in touch with the vendor? Maybe a new zip needs to be uploaded to the store.
_______________
Butterfly Dezignz
-renapd- ( ) posted Fri, 09 March 2018 at 2:22 AM · edited Fri, 09 March 2018 at 2:22 AM
Site Admin
Hi, I've just download the specific zip and it unzips perfectly fine without any problems or errors. Please retry after you clear your browser cache once again! :)
Rena
[[MyGallery] [MyStore]
"Collect moments, not things."
PrestonW ( ) posted Fri, 09 March 2018 at 11:10 AM · edited Fri, 09 March 2018 at 11:11 AM
I didn't have any trouble downloading and extracting this zip file either. Are you using a download manager/accelerator? That could also cause issues.
SpottedKitty ( ) posted Fri, 09 March 2018 at 4:53 PM
Which zip utility are you two using? I know not all unzippers work exactly the same, I used to use two or three others and they didn't all have the same problems with the occasional dud zip file I came across.
I just cleared my cache and downloaded again; exactly the same error. I'm not using a dowmload manager, just Firefox on its own.
Is there any other way I can get a working zip file?
SpottedKitty ( ) posted Fri, 09 March 2018 at 5:25 PM
Okay, it's solved. As suggested upthread, I got in touch with VanishingPoint on sitemail, and they suggested I use WinZip. I did and it worked — with the very first zip I downloaded. Unpacked, installed, and I'm running a test render now.
Very odd, though, I've never had a zip file where I must use WinZip to unpack it.
Thanks, everyone, for your help.
Miss B ( ) posted Fri, 09 March 2018 at 8:49 PM
Glad to hear you got it solved. I used to use 7-Zip until a friend sent me a RAR file, and I couldn't unzip it. I switched to PowerArchiver a few years ago, and have never had a problem since.
I did use WinZip years ago on an older computer, and never had a problem using it, so good to know it's still working well.
_______________
Butterfly Dezignz
