Wed, Feb 12, 6:57 AM CST
Renderosity Forums / New Poser Users Help
Welcome to the New Poser Users Help Forum
New Poser Users Help F.A.Q (Last Updated: 2025 Feb 12 2:40 am)
Subject: how to keep the light and hide the source
the_lova_skul ( ) posted Thu, 29 March 2018 at 12:43 PM · edited Sat, 08 February 2025 at 10:20 AM
i'm rendering from the preview window (because rendering any other way takes FOREVER) and the lights are visible in my scene, and when i uncheck the "visible" option from properties, it gets rid of the light ENTIRELY. how do i make an invisible light that still works?
bwldrd ( ) posted Fri, 30 March 2018 at 4:56 PM
use the preview render engine, not just the preview window.
Consider me insane if you wish, but is your reality any better?
the_lova_skul ( ) posted Fri, 30 March 2018 at 6:46 PM
that's what i AM using, i'm exporting as an AVI
bwldrd ( ) posted Sat, 31 March 2018 at 11:52 AM
I stand corrected, only the infinite lights hide the rest do show up, and sorry, to best of my knowledge there is no way to hide the other types.
bwldrd ( ) posted Sat, 31 March 2018 at 12:16 PM · edited Sat, 31 March 2018 at 12:26 PM
After testing some. The lights I turned invisible by unchecking the "visible" marker still had the light working, and not showing the geometry. They only quit shining light if I Unchecked "On", which turns the light off..
I did notice that if you uncheck visible and the select the light again, poser recheck the visible switch, so after you uncheck it, don't select the light again, else you have to uncheck visible again.
This in 11 Pro though, and you didn't state which version.
Also, I tried replacing the geometries for the lights with nulls(empty geometries) and this worked, but only in new scenes. Saved scenes still loaded the geometries.
the_lova_skul ( ) posted Sat, 31 March 2018 at 3:56 PM
YES thank you! i kept double checking, that's why! (BTW i'm using poser 10)
bwldrd ( ) posted Sat, 31 March 2018 at 4:20 PM
Glad you got it sorted out :)
