Wed, Feb 12, 10:09 AM CST
Subject: interrelation is broken
the_lova_skul ( ) posted Sun, 01 April 2018 at 4:27 PM · edited Wed, 12 February 2025 at 10:01 AM
i've figured out pretty much everything else but this ONE PROBLEM i haven't! i want to know how to get andy (or any other character) to interpolate properly, like for example say i make 4 key frames where he's on a different side of a pole, and instead of smoothly rotating , he detaches from the pole spins around than reattaches on the other side, HOW DO YOU MAKE ANYTHING SMOOTHLY TRANSLATE!?!?!
seachnasaigh ( ) posted Sun, 01 April 2018 at 6:37 PM
Try making/loading a small dummy prop, and place it where its origin has the same X and Z coordinates as the pole. In frame 1, parent the guy to the dummy prop. In the last frame, Y-rotate the dummy prop.
Rance01 ( ) posted Sun, 08 April 2018 at 2:52 PM
Are you rotating the figure body or hip? You may need to add more than four key frames. Check the frames between your key frames and add new ones as needed. You might try posting a screen capture of your setup and/or maybe your animation palette for more helpful advice.
the_lova_skul ( ) posted Thu, 12 April 2018 at 4:54 PM · edited Thu, 12 April 2018 at 4:57 PM
i did that, still not working, i've posted multiple times and i always get that advice, IT DOESN'T WORK!
what's supposed to happen:https://www.youtube.com/watch?v=UyFnWl8DXLM
what happens: https://www.youtube.com/watch?v=i0F6T5dY8WI2018-04-12.png
seachnasaigh ( ) posted Thu, 12 April 2018 at 5:21 PM · edited Thu, 12 April 2018 at 5:24 PM
Your demo animation would be more useful if you slowed the play speed down.
Click the little white triangle beside each of the hip's rotation parameters, and open their graphs. The Y-rot should be a simple 90', as should the X-rot. Z-rot should remain zeroed.
Rance01 ( ) posted Fri, 13 April 2018 at 9:12 AM
I tried uploading a small demonstration to Renderosity but the site did not preview the animated .GIF properly. I'll write a quick page and upload a link to it instead.
Rance01 ( ) posted Fri, 13 April 2018 at 10:43 AM
the_lova_skul, I uploaded resources to http://www.ranquist.net/tutorial/interrelation.htm. It shows the quick animation I made after reading your post. I'm still using Poser 7 but, judging by the screen captures of your animation palette, things haven't changed there all that much. Best Wishes, R
