Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 9:35 am)
Looking at the posts by others on there, you aren't the only one with problems regarding this character.
I doubt there's much you can do, other than contact the creator.
doing some tests I exported this putin head in obj format out of poser ... Then I imported it back to poser and loaded a fresh M4 from the library with morphs ++ Then I used the fitting room reversing things: M4 for object and a for goal: the head ... So when I clicked on create figure of head that calls the morphs transfer window ... The head receives all the morphs of the M4 ... This "seems" to be 50% of the way of a solution because in the tab parametros the mophs are now full and some areas of the face is "like a revolving chick wanting to leave the egg" But when you click on conform To this it ruins some regions of the face.
Hi all I downloaded a character pz3 for m4 on sharecg. http://www.sharecg.com/v/85044/browse/11/Poser/Vlad-for-M4
But it´s no acepting the morphs pack for M4 and your face no quot the morphs. The problem is on head. any tip? note: I on PP2014 Windows 8.1 64bits
