Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
Attached Link: http://www.geocities.com/posermagic
...but I would select the hip of the pants and adjust the Scale by 1 or 2% and see if that worked...or select the model's hip and adjust teh Scale down by 1 or 2%... Sometimes just changing/adjusting the pose fixes it also... Just my .02 cents worth :) TammiLooks like the model has some reversed normals, which makes them transparent, unless the material is double sided. Load it separately and peek inside, you might see some scattered textured polygons. (How do you tell girl chromosomes from boy chromosomes? Peek inside their genes.) I think you can fix them with Poser's grouping tool or UVMapper, but don't have access to my notes right now. By the way, a more discriptive subject line would be more likely to catch the attention of a knowledgeable/helpful person who is scanning through the messages.
I don't know how to fix it but I've seen enough posts here to agree with gryffnn - reversed normals. It is fixable if that is what it is. I suggest you change the Subject line to Help with reversed normals! You'll get a solution in no time. Good luck.
~jon
My Blog - Mad
Utopia Writing in a new era.
