Mon, Nov 25, 12:01 PM CST
Subject: Figures going black
arrow1 ( ) posted Sun, 09 September 2018 at 5:12 PM · edited Mon, 25 November 2024 at 11:45 AM
In Poser Pro 11 I am having some problems with my figures going black when i Add some textures/mats.Mainly with PE Figures but also some Generation 4 figures.Poser often crashes during this process.Should I reinstall Poser? Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
ironsoul ( ) posted Mon, 10 September 2018 at 2:48 AM · edited Mon, 10 September 2018 at 2:49 AM
Sorry only questions, but maybe prompt a memory for someone. Is this happening during preview or Render time? If preview, does switching to sreed help? Does running ezskin fix the problem when it happens with v4? What is the nature of the crash, does the application terminate or does it just hang? If hang could Poser be hunting for texture files? Are the texture files in the material room being displayed ok?
SamTherapy ( ) posted Mon, 10 September 2018 at 4:16 AM
I have seen this before, when loading a normal MAT onto a previous one that uses Snarly's EZSkin. EZSkin sets the Diffuse Color value to zero, so anything loaded to it, and not connected to Alternate Diffuse will show as black. Never had a crash from it, though.
Boni ( ) posted Mon, 10 September 2018 at 9:25 AM
When using EZskin3, I process it as: 1. image maps only 2. Cycles skin 3. glassy cornea fix (assuming you have bopperthijs' plug-in ... available at the SM forum search "EZskin3") This pretty much takes care of the black.
Boni
arrow1 ( ) posted Mon, 10 September 2018 at 5:46 PM
My figures go black while setting up! I import a figure and apply the mat it then goes black and Posers hangs! It only happens now and again. Cheers
ironsoul ( ) posted Tue, 11 September 2018 at 2:48 AM
If you're following the same workflow and its intermittant one thought is the disks where the runtimes are stored could be having problems. Suggest checking the event manger for disk errors.
arrow1 ( ) posted Tue, 11 September 2018 at 4:08 PM
Many thanks for your replies. Cheers
MKDAWUSS ( ) posted Tue, 11 September 2018 at 5:54 PM
Online Now!
It might be time for a driver update too IDK. I've had some funny stuff happen in Poser when a GPU driver acted funny.
Nails60 ( ) posted Thu, 13 September 2018 at 7:30 AM
If it is different textures doing this, rather than one texture sometimes doing it and sometimes not, then it is probably a poor path reference so poser is searching for the missing file(s). Try setting search options to shallow or off under general preferences in the edit menu. Then poser will quickly flash up a can't find warning and you can locate the missing files yourself which can be quicker.
