Fri, Jan 10, 11:01 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: Libraries suddenly out of order
DocMatter ( ) posted Tue, 02 October 2018 at 5:58 PM · edited Fri, 10 January 2025 at 10:57 PM
I just upgraded my Mac to Mojave and when I opened up Poser Pro 11 all the items in my libraries were listed in some random order (no longer alphabetical. I looked in the Runtime folder (in Finder) and everything there was still in the right order. But the Poser library has some new weird order that doesn't make sense. Any ideas how to fix this? Screen Shot 2018-10-02 at 5.57.25 PM.png
Boni ( ) posted Wed, 03 October 2018 at 6:59 AM
Wow, in Windows we can only list our libraries in install order, that is the order in which we installed each runtime. Unless WE install in alpha. order it doesn't happen. Welcome to the Windows system!!!
Boni
raven ( ) posted Wed, 03 October 2018 at 7:52 AM · edited Wed, 03 October 2018 at 7:53 AM
Boni, that looks like a screencap of a figures library, which should be alphabetical order. Runtimes that get added get listed in order of addition, but in our libraries (figure, pose, etc) the folders are alphabetical.
However, I remember reading something about Macs and Runtime sorting order over at the Smith Micro forums, something about the way they list things has changed. I don't know if this has anything to do with your scenario, but you can see the posts I'm referring to here (specifically by anomalaus and bagginsbill).
https://forum.smithmicro.com/topic/9091/python-method-to-add-a-runtime-folder-to-library/11#
DocMatter ( ) posted Wed, 03 October 2018 at 8:00 AM
Here's the response I got from Smith-Micro, but I can't find the file they're talking about.
You need to change the option in the Poser Preference for the Library using a Text Editor. The Poser Preferences is located at Mac “~/Library/Application Support/Poser Pro/11/Poser Prefs”
​Open the file using a Text Editor and locate the line LIB_ITEMS_SERVER_SORT Setting it to 1 from 0 should fix the issue.
Boni ( ) posted Wed, 03 October 2018 at 8:27 AM
Thanks Raven for the correction. I see what you mean. Hope this gets all sorted out. 😄
Boni
DocMatter ( ) posted Wed, 03 October 2018 at 6:43 PM
Just an FYI, the Smith-Micro info worked, but it was tough finding the right folder. You have to use the "Go menu" in finder and then hold down the "Option" key so the "Library" folder will show up. Why it doesn't show up normally, I'll never know.
ironsoul ( ) posted Thu, 04 October 2018 at 11:26 PM · edited Thu, 04 October 2018 at 11:28 PM
If it helps for future reference the "~" character at the front of the location is shorthand for the user's home directory.
DocMatter ( ) posted Fri, 05 October 2018 at 9:31 AM
Yeah, I looked there, but the library folder wouldn't show up unless I use the "Options" key. Apple weirdness!
RobZhena ( ) posted Mon, 15 October 2018 at 6:11 AM
That fix was necessary for High Sierra, too, so it’s not a Mojave effect.
DocMatter ( ) posted Mon, 15 October 2018 at 10:29 AM
That's weird, because I didn't have the problem with High Sierra.
