Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 11 4:44 am)
Okay, I think I finally got DSON installed. (Had to make DIM think Poser 11 was really Poser 2014.) But now I'm having trouble using it. I'm trying to get all my G2 figures and such from DAZ into Poser, but when I try and open them in Poser, nothing shows up. There are icons for them in the DSON folder I set up, but when I click on them, nothing shows up. Poser claims there's something there, but there isn't. Any suggestions?
just a heads up on using DSON in poser 11, it is very unstable on genesis 2 female if you are going to put a few characters in the scene that is, also use v4 poses as the gf2 poses tend to scramble up in frame animation if you use frames to layer a scene, if you are on frame 50 etc and change a pose it will throw everything back to frame 1 settings with a lot of GF2 poses, so if this does happen use v4, might need a little tweak on fingers toes! Also other problem is parts of the gf2 body tend to stretch and stay stuck in zero a reload sorts that problem out!
i can't install dson in Poser 11 and i don't own an older version because i have a new PC. i have only saved my runtime libary (184GB) Is there a cance to use my genesis1/2 products
