Fri, Nov 1, 9:26 PM CDT
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Oct 24 8:57 am)
banner
Subject: dson do not work in poser11
allvieh ( ) posted Sat, 20 October 2018 at 4:20 PM · edited Fri, 01 November 2024 at 9:23 PM
i can't install dson in Poser 11 and i don't own an older version because i have a new PC. i have only saved my runtime libary (184GB) Is there a cance to use my genesis1/2 products
donnena ( ) posted Sat, 20 October 2018 at 8:14 PM · edited Sat, 20 October 2018 at 8:23 PM
Did you install DSON to the Poser11 install and Map your DS Libraries
Here's DAZ's Walk thru http://docs.daz3d.com/doku.php/public/software/dson_importer/poser/userguide/dson_installation_requirements/tutorials/dson_installation/start
Andy!
allvieh ( ) posted Sun, 21 October 2018 at 11:56 AM
i tried to install but allways failed because installmanager can't find Poser 2014 or 2012
allvieh ( ) posted Sun, 21 October 2018 at 3:27 PM
allvieh ( ) posted Sun, 21 October 2018 at 3:34 PM · edited Sun, 21 October 2018 at 3:37 PM
after i reinstalled an old poser 2012 .i could install DSON but it does't work . error aslike the screnshott in the box before !!! who nows why ? Allvieh
Nails60 ( ) posted Sun, 21 October 2018 at 6:35 PM
Don't use install manager. Manual download, unzip, put the python files in your main poser runtime, in runtime with other python files, in mine it is folder addons. Main poser runtime is in programs folder under smith micro, poser 11
DocMatter ( ) posted Tue, 18 December 2018 at 6:50 PM
I can't get it to install either. Using DIM, it says it can't find the Poser 2014 files. And manual downloading doesn't work. When I do that, it wont run. BTW, I have a Mac and am downloading the Mac version.
DocMatter ( ) posted Wed, 19 December 2018 at 2:05 PM
Okay, I think I finally got DSON installed. (Had to make DIM think Poser 11 was really Poser 2014.) But now I'm having trouble using it. I'm trying to get all my G2 figures and such from DAZ into Poser, but when I try and open them in Poser, nothing shows up. There are icons for them in the DSON folder I set up, but when I click on them, nothing shows up. Poser claims there's something there, but there isn't. Any suggestions?
kol_2005 ( ) posted Wed, 26 December 2018 at 1:42 PM
just a heads up on using DSON in poser 11, it is very unstable on genesis 2 female if you are going to put a few characters in the scene that is, also use v4 poses as the gf2 poses tend to scramble up in frame animation if you use frames to layer a scene, if you are on frame 50 etc and change a pose it will throw everything back to frame 1 settings with a lot of GF2 poses, so if this does happen use v4, might need a little tweak on fingers toes! Also other problem is parts of the gf2 body tend to stretch and stay stuck in zero a reload sorts that problem out!
