Fri, Feb 7, 1:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Exclude Sky Dome from effects of Atmosphere?
aztecmarco ( ) posted Wed, 05 December 2018 at 2:00 PM · edited Fri, 07 February 2025 at 1:10 AM
Hello, I'm trying to create a space themed image using Coflek-gnorg's Space Debris props. Is there a way to add an atmospheric effect to the scene without occluding the space prop that I'm using as a backdrop? Please notice the effect on the attached image. Thank you in advance for any help you can give. I should add I'm using Poser Pro 11.example.jpg
Boni ( ) posted Wed, 05 December 2018 at 3:17 PM
I'm not sure what you are asking ... but if you are referring to the construct (sky dome that opens when Poser 11 loads) then you merely make it invisible in "properties".
Boni
aztecmarco ( ) posted Wed, 05 December 2018 at 4:58 PM
It's kind of like the poser construct but it a sphere object with a star field texture applied to it. I actually want to be able to see it without the Poser atmosphere material affecting it. So basically you would see the effect of the atmosphere on all the object in the scene except the surrounding sphere/environment object. Thank you so much for your reply, I really do appreciate it. Sorry to be so vague about it, it's kind of a rough concept to try and explain. Attached is a version with no atmosphere effect applied. Example two.jpg
Boni ( ) posted Wed, 05 December 2018 at 5:58 PM
I hate to say this ... but I don't believe you can pick and choose what the atmosphere (by its very nature) can affect. Its purpose is to affect the entire scene if you think about it.
Boni
raven ( ) posted Thu, 06 December 2018 at 11:27 AM
You could try maybe adding an appropriately sized ball prop with a volumetric texture on it to simulate atmosphere. It may give what you're after.
You could possibly try using a material similar to the effect in this thread at SM's forums.
https://forum.smithmicro.com/topic/1921/floor-fog-with-scattervolume-in-cycles
aztecmarco ( ) posted Thu, 06 December 2018 at 1:11 PM
Awesome, I'll give that a try. Thank you both for your help.
bagginsbill ( ) posted Wed, 12 December 2018 at 5:06 PM
Which render engine? FireFly or SuperFly?
What unit of measure do you normally think in, feet or meters?
aztecmarco ( ) posted Thu, 13 December 2018 at 10:46 AM
Sorry for the late reply, I'm using FireFly. I'm still not comfortable with SuperFly.
bagginsbill ( ) posted Fri, 14 December 2018 at 1:17 PM
I asked two questions. Second was What unit of measure do you normally think in, feet or meters?
aztecmarco ( ) posted Mon, 17 December 2018 at 1:00 PM
Oop sorry Feet
bagginsbill ( ) posted Wed, 19 December 2018 at 10:02 AM · edited Wed, 19 December 2018 at 10:14 AM
OK first I set my Poser Display Unit to feet.
I have set up some spaceships and some squares. The first square is at world origin 0, 0, 0. The other squares are each 100 feet behind the previous, and each spaceship is just behind and beside each square. So the backmost spaceship is a little over 400 feet from the origin. I do not yet have a background, so here are my spaceships rendered as png.
Because this is a PNG without background, these ships will appear in this forum against whatever background color you see here.
bagginsbill ( ) posted Wed, 19 December 2018 at 10:04 AM · edited Wed, 19 December 2018 at 10:05 AM
Now I have loaded a background image (horsehead nebula) on a poser one-sided square that I scaled and positioned behind all the ships. The nebula prop is zTran -800 feet so is very far back. You may have to adjust your camera yon to see something this far away.
bagginsbill ( ) posted Wed, 19 December 2018 at 10:06 AM
The stark white light does not give a good impression of being in the nebula so I wish to use atmosphere to help the illusion a bit.
I pick a green color from the nebula image itself and set up maximum color blend at 600 feet.
bagginsbill ( ) posted Wed, 19 December 2018 at 10:07 AM
The atmosphere nicely colors my ships. Unfortunately, the atmosphere completely obliterates my background prop as it is more than 600 feet away.
bagginsbill ( ) posted Wed, 19 December 2018 at 10:08 AM
What I do now is set up the atmosphere to basically get turned off for any pixel that is more than 500 feet away. You can use any number in the place indicated for your cutoff distance.
bagginsbill ( ) posted Wed, 19 December 2018 at 10:09 AM
Now my background prop is unaffected by the atmosphere.
I believe this is what you were trying to achieve.
bagginsbill ( ) posted Wed, 19 December 2018 at 10:10 AM
After hiding the squares and rendering larger, this is the result.
bagginsbill ( ) posted Wed, 19 December 2018 at 10:16 AM
The same will happen with a sphere, so long as the camera is not seeing any part of the sphere that is closer than the cutoff distance. My EnvSphere defaults to a radius of 750 feet so easily works with this setup, so long as the camera is mostly pointing straight along the Z axis.
bagginsbill ( ) posted Wed, 19 December 2018 at 10:21 AM
Here I have a cloudy star field on my environment sphere which I enlarged to 1500 feet radius.
bagginsbill ( ) posted Wed, 19 December 2018 at 10:23 AM · edited Wed, 19 December 2018 at 10:33 AM
Boni posted at 11:23AM Wed, 19 December 2018 - #4341295
I hate to see you say this because obviously I disproved it. ?
aztecmarco ( ) posted Wed, 19 December 2018 at 10:56 AM
You sir are a genius, this is exactly the effect I was looking for. Thank you so much and Happy Holidays!
