Tue, Nov 19, 11:39 PM CST
Subject: Apply material to one side/face of a cube only?
BatmansRenderosity ( ) posted Wed, 12 December 2018 at 2:07 PM · edited Tue, 19 November 2024 at 11:24 PM
I have been meaning to ask this for a while and have been searching for answers but can't find where I should be looking.
In Maya and 3DSMAX you can select a side and face and apply a material to just the face.
In Poser in materials, you can select parts of an object from the drop-down menu. That's how I have managed materials before.
However, with a cube, I am fighting the advanced settings Image Map properties, such as scale an offset, and can't get something just on one side/face of a cube.
So I am probably doing this wrong.
Any help would be appreciated.
Miss B ( ) posted Wed, 12 December 2018 at 2:36 PM · edited Wed, 12 December 2018 at 2:39 PM
Are you referring to the "box" found in Poser's Props > Primitives folder? If so, there's only a "preview" node for texturing, which is why you can't texture only one face of the box/cube.
IOW, the object has to be UV mapped in order to texture only selected parts/faces of the object. If it hasn't been UV mapped, then your only option is to apply the one color/texture to the whole object.
Software like 3DS Max, Maya, Blender and such are modeling software apps, so they have the option to UV map whatever you create. Poser isn't a modeling software app, so there aren't any options, that I'm aware of, that allow you to do so from within Poser.
_______________
Butterfly Dezignz
bagginsbill ( ) posted Wed, 12 December 2018 at 4:18 PM
Use the grouping tool, create a group with the faces you want, then assign a new material to those faces.
This will allow you to color them as a group, but distinct from any other faces.
bagginsbill ( ) posted Wed, 12 December 2018 at 4:21 PM
Miss B posted at 5:20PM Wed, 12 December 2018 - #4341664
Nope. UV mapping is about defining the UV coordinates for each vertex. Using the grouping tool, we define at will the materials associated with the faces (polygons).
To use a texture map image, you need UV mapping. To use multiple, separate materials you just use the grouping tool. (Or an external modeling tool)
bagginsbill ( ) posted Wed, 12 December 2018 at 4:25 PM
Next someone will ask how you get rid of a material you don't need anymore because you disassociated all polygons from that material to some other. The answer is Poser can't do that. You would need a Python script or external tool to modify the saved file.
operaguy ( ) posted Wed, 12 December 2018 at 5:56 PM
Related to this thread ... but I admit a partial hi-jack ...
BB, do you have time and inclination to respond to "how do you animate transparency on an object, here:
https://www.renderosity.com/mod/forumpro/?thread_id=2929213
::::: Opera ::::
Miss B ( ) posted Wed, 12 December 2018 at 9:53 PM
bagginsbill posted at 10:52PM Wed, 12 December 2018 - #4341671
Making notes, as I've not used the grouping tool much, so didn't realize that was what you would use it for. As always BB, you're the man! 😉
_______________
Butterfly Dezignz
