I was trying a mermaid, Pearl, with Koz hair, so yes, hair was the main problem. She also has lots of jewerly props. The problem with taking them to Bryce is Bryce doesn't identify the meshes, so I have to bring everything over one piece at a time using a tall cylinder for heigh reference. Once everything is over then I have to recombine and group everything, after I apply the textures to the individual parts. The trans mapped hair is were I finally gave up. It also doesn't help the the model looks like crap in bryce light. I'm just doing to many things wrong and don't know what to adjust to make it right. :( For example if I had a step by step (I mean a real step by step) of how the woman with the hawk was made I'd be set. So far I have a mermaid with no hair or jewerly and she looks nasty.
Attached Link: http://www.awakemm.com/poserarcana/index.asp
Poser Arcana has a very detailed tutorial about how to import Poser characters into Bryce.LVS - Where Learning is Fun!
Attached Link: http://www.brycetech.com
follow the link,there is a tut called "poser to bryce" and in my opinion its one of the best.(really step by step) the hair is really making trouble,use in the beginning one that has only one transmap(with 2 or more its getting worse)you don't have to ungroup things to apply or modify object textures!! you hold the ctrl key down while you click the object and you can select individual object within a group. it sounds to me like instead of poser to bryce help perhaps some bryce help would work too... i mean, once you get your objects imported into bryce it's all bryce techniques. the links above have allot of great information though and are well worth reading. so when you get your poser stuff rendered in bryce make sure you post it!! we all wanna see what you are doing 8^}
I spend so much time banging my head against the wall trying to render a poser figure in bryce that I hurt. I can get the figure there, and even apply the texture. But then applying the bump maps, trans maps, settings, etc. just bury me. Seems there are just no good tutorials on the subject as I can never finish anything in bryce. My question is, 'Will Bryce 5 and Poser 5 be more compatible?' Is it asking too much to export a Poser file in 'Bryce' format. Then open Bryce, open the file and ALL textures, maps, props, etc. automatically apply? Does it have to be hard? Will it ever get better?
