Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 01 3:49 pm)
Parenting a prop would never work for this the Paul/Pauline Face controls are driven by facial bones. similar to the Genesis 3/8 figures
One could theoretically add some new facial bones to V4 and edit her CR2 to achieve this feature according a post in this poser forum thread:
You can easily link props to morphs, I do it all the time for stuff.
Load your figure. Load the prop you want to use and position it. If you want the origins to be 0,0,0 on the prop, export it, then re-import it. Parent the prop to V4's head.
Now that you have the prop there, decide what you want the 3 directions (x,y,z) to do. (You can do far more than 3 things with each prop, every channel in the prop can be linked to another prop, figure, light, camera, whatever....) Lets use blink. Add a dependency to the x axis. Click start learning in the editor. Set blink to -1 as (in V4's case, eyes closed). Move the prop on the x axis a bit, set blink to .5 (Eyes wide open) Click stop learning in the dependency editor. Set the min and max x values on the prop x axis and force limits in the setting area so you can't drag the prop further than the setting.
Poof, the impossible to do in Poser prop Blink controller is now done....
Wolf, stop telling people what you can't do in Poser. It doesn't matter if you can't do it...... You have repeatedly posted you don't even use Poser anymore. Telling people that something can't be done when it obviously can is nothing more than you answering in a thread with absolutely nothing to add but disinformation..
Some things are easy to explain, other things are not........ <- Store -> <-Freebies->
shvrdavid, thank you. I will explore this later today. I have spent parts of the last 10 days attempting to learn rigging from the ground up, in order to place helper bones in V4 head to accomplish direct manipulation for lip sync. I'm making progress with that, but if i can simply connect a prop to the already-existing morphs, that would be spectacular.
Can you parent the prop to, say, head, so that the prop stays positioned around her head no matter the pose?
Problem: when I click on the prop to move it, or even move it's dial, the ball's y goes to zero (drops to floor).
Sequence:
Place ball next to the head.
Select the V4 head.
Scroll down to "Browup-down"
Open the dependency editor on that morph.
Switch tabs from Value operations to Keyed Dependencies. (There are already two dependencies in place, for the r- l- morphs)
Click on "start teaching."
Click on the ball with the intention of moving it a little. Ball drops to the floor.
You need to open the dependencies on the parented prop. Not on the V4 morph. First parent the prop to her head, then open dependencies on the prop axis you want to use. Now you can select V4 head and add the morph you want to it.
"Dream like you'll live forever. Live like you'll die tomorrow."
Okay, working! I've got a prop with a y-axis dependency to the V4 morph BrowUp-Down. When you grab the ball and move it up/down, the brows raise/lower.
Thanks shvrdavid and ghostman.
I may or may not abandon my "18 helper bones for facial animation" project. First I want to see if this idea...prop with morph dependency...gives me the control I want.
Is it possible to "build" a morph direct manipulating system by parenting a primitive to a morph? Specifically, I instead of spinning Expression dials on V4, I'd like to directly manipulate her face morphs. This would establish the function supplied to Paul and Paulina in PoserPro 11. Possible? Other ways?
::::: Opera :::::
