Wed, Jan 8, 7:03 PM CST
Subject: black objects back again....aaarrrggh....
3dnickel ( ) posted Wed, 17 October 2001 at 11:22 AM ยท edited Sun, 22 December 2024 at 11:14 PM
Okay...I took a basic square (poser prop) and pulled the upper right corner to to lower left corner, forming a right triangle. Export as .obj - import to fresh poser studio. Render materials are white, white, black, black. Changed reflection to white. New triangle is totally black - doesn't respond to paint bucket. Only ambient settings make any difference. Set material settings to match that of original square. No good. Went into .pp2 file and compared material settings for original square and new triangle. Set triangle to same as square. No good. New poser studio. Export square and torus as .obj files - import to new studio. Torus is fine. Square is totally black - same as earlier triangle. Is there something about 2-sided objects that screw up when going through export-import process? Should this be in the technical forum? Any help would be appreciated.
c1rcle ( ) posted Wed, 17 October 2001 at 11:59 AM
don't panic, you need to change the colors to white black black white and it'll go back to what it was before
3dnickel ( ) posted Wed, 17 October 2001 at 5:50 PM
Change to white black black white didn't work. Removing .rsr files and re-opening Poser didn't work. Top image is wedge and triangle in smooth shaded mode. Bottom image is wedge and triangle in hidden line mode. (Wedge is made of 2 triangles and 2 squares - all double sided. I flinched at trying to line up edges with a single sided square. Maybe that's what's required.)
Anthony Appleyard ( ) posted Thu, 18 October 2001 at 5:43 AM
In the geometries of some of these standard Poser geometricals, the lines defining the faces start with fo instead of f .
3dnickel ( ) posted Thu, 18 October 2001 at 11:40 AM
blither blither blither NOW they're working!!! aaaarrrggghhh.... I didn't change any settings since last night....didn't restart windows...didn't restart Poser...just went away and came back.... the darn things imported perfectly - (well, other than I just noticed the wedge sides are slightly bowed) - but.... *** just SHOOT me *** (or better yet - send me a free copy of Poser 5 - okay, just kidding...) no, really - send it anyway... ;)
