Sat, Jan 11, 3:28 PM CST
Subject: LaFemme crashing Poser 11 Pro?
gwp ( ) posted Thu, 07 February 2019 at 5:53 PM · edited Sat, 11 January 2025 at 2:35 PM
Is anyone else having problems with Poser 11 Pro crashing while using LaFemme? After this happened several times I installed the latest update for Poser 11 Pro but still had a crash occur after I applied a V4 pose to LaFemme (which worked fine except for the feet) and then tried to adjust the feet. No one else has mentioned crashes, so I am trying to figure out what is going wrong for me.
randym77 ( ) posted Thu, 07 February 2019 at 8:39 PM
I'm not having any problems. I've applied V4 and Dawn poses to LaFemme, with no crashes.
DCArt ( ) posted Thu, 07 February 2019 at 9:00 PM
It sounds like you might have IK on, if the poses are working on everything but the feet and then you try to adjust the feet. Choose Figure > Use Inverse Kinematics and then uncheck both feet. The poses should work better after that and you'll also be able to move the feet more easily.
hborre ( ) posted Thu, 07 February 2019 at 9:12 PM
I haven't had any crashes with IK on while posing La Femme. However, her feet still don't cooperate with V4 poses.
randym77 ( ) posted Thu, 07 February 2019 at 9:28 PM
No crashes with IK on for me, either. And the feet look pretty good, with IK or not. It's the hands that can look kind of odd.
A_Sunbeam ( ) posted Fri, 08 February 2019 at 1:29 AM · edited Fri, 08 February 2019 at 1:30 AM
Every now and again double-clicking doesn't select an item in the library when I've got a LaFemme character. Dragging an item to conform also doesn't work, or selecting a light. I have to exit poser and open the file again to get it working correctly. And there have been a couple of freezes needing a force quit. (iMac)
infinity10 ( ) posted Fri, 08 February 2019 at 4:36 AM
I think it is because nVidia just released an update for the graphics driver and you need to install that for Poser to work properly ??
Eternal Hobbyist
Boni ( ) posted Fri, 08 February 2019 at 6:40 AM
Just as an added side note ... Universal Poses are not recommended for La Femme. Otherwise, I haven't had any issues with V4 poses and La Femme.
Boni
