Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Sep 16 2:29 pm)
Conforming clothes responds to the figure's morphs and usually not the other way around. So if you want voluptuous as your figure morph, you dial the morph for V4 and the clothing should conform along with her. However, the morph present in the figure should exist in the clothing also, otherwise, you will only see changes in the figure and not the clothes. If you dial morphs in conforming clothes, V4 will respond to those changes, but that is not the way it is intended to work.
So I'm having a problem sometimes when I try to fit an outfit to a figure. If I go to the article of clothing and select its body morph and try to use any of the morphs (ex. voluptuous), it will not work or when it does work, it will change the V4 figure. Can anyone tell me what's going on?
Thanks in advance for any insight.
