Forum Moderators: tim, msansing, ebasham
MarketPlace Customers F.A.Q (Last Updated: 2025 Jan 25 4:03 pm)
Contact and Support Information:
To reach our Marketplace staff, please open a support ticket at
support.renderosity.com
Our goal is to respond to support tickets within 24 hours, 7 days a week.
Are you using the product in Poser or DS? If DS then from reading the description you will need to alter the surfaces to either a 3dl shader or an Iray one and then alter the settings to emit light. Although the title says DS and Poser the description says the mats will need to be altered, ''Note :- The set comes in Poser format only as they all work (with the exception of Materials) well in Daz Studio.''
It's extremely easy to make the lights glow in DAZ under IRay. You just add an emissive shader to them. 3Delight it can be done, but it's not as easy. Are you using it in Iray or 3Delight. If it's Iray? I'll be happy to walk you though how to do it. SImon-3D, I've got that set, I'll work up some Iray materials for it . Give me a week.
In the meantime here is a tutorial on how to make hair emissive. The crux of it is you make the emissive color of the surface something other than black. I'll write up some directions on doing it specifically for this set.
https://thinkdrawart.com/light-emitting-shaders-and-surfaces-in-daz-studio-iray
That's it. Of course you can save the settings so you don't have to do it each time. Or there are a lot of really good emssive shaders out there which basically control the settings for you.
The main ones I fiddle with are Emission color Emission Temperature Two Sided Light on Luminace Luminance Units (I set it to Kcdm2, It defaults to cdm2
Here's the sign in the set where I changed the values of three letters.
I haven't messed around lately with custom colored emissives, but if I recall correctly, I'm pretty sure you need to set the color temperature "K" to zero so it displays the proper color. Then the light color it gives off will be the specified emissive color instead of that dictated by the K-scale value. I had a hell of a time figuring it out a while back when I was trying to make greenish glowing uranium glass in the presence of UV light.
I tried contacting the vendor on Feb 17th but have not heard back. I would like a refund as I don't believe that this product work as I expected. Thanks
"Maybe I'm missing something but the neon lights don't actually emit any light. Is this correct? Is there an easy way to do this? Thanks"
