Mon, Jan 6, 10:15 PM CST
Subject: "Neutral" light for testing skins
vholf ( ) posted Fri, 10 May 2019 at 10:56 AM · edited Sun, 22 December 2024 at 10:14 PM
I looking for advice on what is considered a "neutral" light for testing different skin textures and shaders. What is the standard setup for this? 1 white light? 2? 2 in front and from behind? Any input is appreciated
Thanks.
SamTherapy ( ) posted Fri, 10 May 2019 at 1:28 PM
Single white light and Envirosphere without texture is going to give a relatively even white light. That's how I'd do it, anyhow.
dlfurman ( ) posted Fri, 10 May 2019 at 2:56 PM
Tweak the light intensity also. It will not be 100% 55-67% works pretty well, Play around to what your eyes says is good.
ironsoul ( ) posted Fri, 10 May 2019 at 3:50 PM
BB had somekind of Gamma and Exposure meter to help with getting the exposure correct but my Googlefu is failing, maybe someone still has the link.
Miss B ( ) posted Fri, 10 May 2019 at 8:38 PM · edited Fri, 10 May 2019 at 8:38 PM
ironsoul posted at 9:36PM Fri, 10 May 2019 - #4351535
If you're referring to his BBGammaMeter, you can find it, and whole lot more of his goodies, in his File Cabinet
_______________
Butterfly Dezignz
caisson ( ) posted Sat, 11 May 2019 at 8:57 AM
Pretty much what SamTherapy said.
The standard lighting I use to test all materials I make is a single white infinite light set to 100% intensity on the grounds that it's the simplest possible setup that works well. As I use Poser 11 with Superfly, which comes with free reflections on everything all the time, I use the Poser Ground with a simple material for indirect reflected light - White and Blackout materials are in the Construct folder in Poser 11 Materials. Changing one of those materials to a mid-grey colour will give a nice neutral test setup (for speed when test rendering I switch off Visible in Camera in the Ground Properties too).
I check exposure like a digital photo - render a low quality test, save it, then look at the Histogram in an image editor.
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
