Mon, Jan 6, 2:35 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2024 Dec 30 12:17 pm)
banner
Subject: Advice for Poser Pro 11 Uninstall / Reinstall?
mmitchell_houston ( ) posted Wed, 05 June 2019 at 10:22 AM · edited Sat, 04 January 2025 at 5:16 PM
I am upgrading my laptop today (replacing a 256 GB SSD with a new 2 TB SSD.
CURRENT CONFIGURATION:
  • 256 GB SSD is the boot drive with Win 10 (there are almost no apps installed on this drive): My C drive.
  • Poser and Runtime (along with almost all of my other apps) are installed on a 1 TB hard drive (7200 rpm): My D drive.
NEW CONFIGURATION & ACTIONS:
  • I am cloning the old SSD boot drive to the new SSD, then using software tools to increase the size of the partition (I've done this before on other systems without issue – in fact, Acronis software makes it downright easy!).
  • I will then remove the old (small) SSD.
  • I will then uninstall Poser Pro 11 from the D drive.
  • And then install a fresh copy of Poser Pro 11 onto the new SSD drive.
  • I will then copy my old Runtimes over to the new SSD.
  • And then I will use the Poser interface to add these new libraries.
I know I need to keep an eye out for my Favorites (don't want to lose them), but is there anything else I need to be mindful of in this scenario? Thanks in advance for any tips or advice!
(Why the move? Increased speed in accessing my assets and hopefully this will fix some issues I've had with the stability of my current Poser installation.)
System: Lenovo Legion Pro 7 16IRX9H Laptop | Windows 11 Professional | 32GB RAM |  14th Gen Intel® Core™ i9-14900HX | Nvidia RTX 4090 Laptop GPU 16GB 9728 CUDA Cores
mikemitchellonline.blogspot.com   |   Poser Noir Comics Tutorial   |   Illustrations Honored by Renderosity
donnena ( ) posted Wed, 05 June 2019 at 11:05 AM
you may want to grab your preferences from the Users/You/AppData/poserpro/11/
Andy!
mmitchell_houston ( ) posted Wed, 05 June 2019 at 11:45 AM
donnena posted at 11:45AM Wed, 05 June 2019 - #4352710
you may want to grab your preferences from the Users/You/AppData/poserpro/11/ Thanks! That is just the sort of thing I would have forgotten.
mmitchell_houston ( ) posted Wed, 05 June 2019 at 7:15 PM
EDIT TO ORIGINAL POST: I should have said AOMIE Backupper Pro and AOMIE Partition Assistant as the software I used to clone my old C drive over to the new one and then resize it. From start to finish ON JUST THE HARDWARE INSTALL AND THE OS CLONE it took me 45 minutes to finish everything.
Next up, time to install a fresh version of Poser Pro 11 and Daz Studio 4.x.
