Sure! The Scatter Volume node shouldn't be there - I used it because I'd seen a skin shader with it from years ago, and started adding more nodes to get the look I wanted. Turns out the node wasn't even being rendered with Branched Path Tracing off to begin with, for some reason - so the rest of the shader was responsible for the entire look I wanted, and the Scatter Volume was causing all that weird redness/blackness with Branched Path Tracing. I just deleted that node and everything worked.
More details, and some tips for the SubsurfaceScattering node, on the thread I was given this answer: https://forum.smithmicro.com/topic/9665/cycles-sss-skin-and-branched-path-tracing/14
Feel free to call me Ohki!
So, I got reported a problem with my already released character set.
Here's the Superfly version of her skin shader (External outputs plugged to Cycles root, External inputs plugged to diffuse, bump and spec maps):
I've been testing her always with Branched Path Tracing off and Progressive Refinement on, as that works best for me and I thought the only difference in those were render times and quality in specific things. However, a customer of mine uses Branched Path Tracing on. Here's my trouble.
Branched Path Tracing off:
Branched Path Tracing on:
The only difference I could get was if I turn Volume Samples higher:
What gives? Is there anything I can tell my customer to do without me having to change her shaders (as this is an already released product)?
