Wed, Feb 26, 11:59 PM CST
Forum Moderators: RedPhantom
Subject: LaFemme Celebrity Morphs
  • 1
  • 2
Eric Walters ( ) posted Fri, 14 June 2019 at 11:15 PM
Kristin Kreuk from Smallville? Eric Walters posted at 9:13PM Fri, 14 June 2019 - #4353184
Looks great!
qaz posted at 9:10PM Fri, 14 June 2019 - #4352972
This is my first La Femme morph of a real person, not a well known person though. I have included her with an old V4 celeb morph I did a few years ago. Interesting comparison.
qaz ( ) posted Sat, 15 June 2019 at 3:59 AM
It is indeed Kristin Kreuk !! I'm not happy with Lynda Carter yet. Need to change texture. I am still going to release Ulrika, but as she is supposed to be a base for other figures, I need to practice with face shapes .
Latest iteration
Eric Walters ( ) posted Sun, 16 June 2019 at 9:02 PM
A definite resemblance! Glad you will release Ulrika. BTW: you CAN use displacement maps with cycles. You need to set up subdivision. Here is a La Femme character of mine. I used the morph brush to make the ears pointed. The scale pattern is from a displacement map. I set Subdivision to 2 on the head. qaz posted at 6:55PM Sun, 16 June 2019 - #4353193
Latest iteration
knyghtmare2021 ( ) posted Mon, 17 June 2019 at 11:33 AM
I've been looking at the LaFemme WW morph... can you try smoothing the area under the nostril? There seems to be a weird distortion. It's present on the LizardWoman(?) as well...
qaz ( ) posted Mon, 17 June 2019 at 4:05 PM
knyghtmare2021 posted at 3:27PM Mon, 17 June 2019 - #4353293
Thanks for the feedback. That distortion is called a philtrum. But look around the mouth area. Does it look lumpy to you ? That's due to distortions in the underlying geometry. As I've pointed out elsewhere in this thread, I'm finding it difficult working with such a low poly figure and I'm actually having to move individual vertices for goodness sake. I'm not worried about it at the moment as the morph is still a work in progress, and I will look at smoothing issues when I'm near the end. It's more of a sketch at the moment,
As for Lizard Woman, that's Eric's baby. It may be due to using facial control chips on the smile. I've noticed they break up the geometry on the region above the lips. This is again, I believe due to insufficient vertices on the face. The face chips can be used for small movements and you can get some good effects.
Eric Walters ( ) posted Mon, 17 June 2019 at 7:13 PM
To Qaz listen you must! I used control chips for the smile. Lizzie La Femme uses displacement with Subdivision set to 2. qaz posted at 5:10PM Mon, 17 June 2019 - #4353320
rokket ( ) posted Tue, 18 June 2019 at 3:20 PM
Since Wonder Woman was mentioned... I was working on a WW suit for LeFemme. I just threw some temporary textures on the suit so I could show it. LaFemme WW.png
qaz ( ) posted Tue, 18 June 2019 at 3:52 PM
rokket posted at 3:49PM Tue, 18 June 2019 - #4353377
Awesome. I must say I was thinking of you when I mentioned the suit :) By the way, she is going to have some considerable boobage :)
rokket ( ) posted Tue, 18 June 2019 at 4:24 PM ยท edited Tue, 18 June 2019 at 4:25 PM
qaz posted at 2:21PM Tue, 18 June 2019 - #4353381
I am working on her default frame, but if you can give me an idea of how big they would be, I could morph her and get it to fit. I am thinking since it's going to be a Linda Carter morph, I will just find a good reference image and make it work. LaFemme is pretty east to model for. I am working on the other pieces of the suit right now. To get to where I want to with this, you'd have to have the Blackhearted HD morphs, and Deecey's body morphs for her...
qaz ( ) posted Tue, 18 June 2019 at 5:56 PM
I'm going for accuracy this time so a single body injection morph which I will create. She is tall with wide hips, micro waist and top heavy. I'll PM you some photos that leave nothing tp the imagination. I'd hang fire until i've done that. Here is my V4 version:
rokket ( ) posted Tue, 18 June 2019 at 6:40 PM
Ok, no problem. I can work off that. I'll wait for the PM.
rokket ( ) posted Tue, 18 June 2019 at 6:54 PM
I am working up a NSFW render of the body I would use, so I can compare the different approaches...
rokket ( ) posted Tue, 18 June 2019 at 7:47 PM ยท edited Tue, 18 June 2019 at 7:49 PM
rokket ( ) posted Tue, 18 June 2019 at 7:48 PM
Why isn't my image showing up?
rokket ( ) posted Wed, 19 June 2019 at 12:35 AM ยท edited Wed, 19 June 2019 at 12:36 AM
rokket ( ) posted Wed, 19 June 2019 at 12:37 AM
Now I can't put a nudity tag on it.... What gives?
qaz ( ) posted Wed, 19 June 2019 at 6:31 AM
A little chunky for my taste Rokket. I want mine to look like Lynda.
rokket ( ) posted Wed, 19 June 2019 at 10:00 AM
qaz posted at 7:58AM Wed, 19 June 2019 - #4353456
I got your PM's and I will start working on getting that body. Do you have Blackhearted's SD and HD morphs and Deecey's LF Body Kit morphs for her?
rokket ( ) posted Wed, 19 June 2019 at 10:03 AM
I made some progress on the original suit. At least now I know how to get the results I want when I make the next one...
rokket ( ) posted Wed, 19 June 2019 at 10:57 AM
WIP.png I softened the body up a bit and made the breasts a bit fuller. I will work on it some more later today.
qaz ( ) posted Wed, 19 June 2019 at 1:03 PM
Cool
rokket ( ) posted Wed, 19 June 2019 at 1:39 PM
Is she close?
qaz ( ) posted Wed, 19 June 2019 at 1:57 PM
Latest Iteration
qaz ( ) posted Wed, 19 June 2019 at 2:03 PM
What celebs do people want to see for La Femme ? So far we have : Jamie Murray Morena Baccarin
rokket ( ) posted Wed, 19 June 2019 at 2:15 PM
Scarlett Johannsen would be a nice one...
Redfern ( ) posted Thu, 20 June 2019 at 9:33 AM
Hmm, now there's a poser (pun too obvious to ignore).
I'm so absurdly out of date with the current string of celebrities, I wouldn't know 90 percent of the faces that I saw..
So I'll just rattle off some people I'd personally like to see even if the chances of them being made are next to nil.
Really, almost any of the women who appeared in "Doctor Who", both the revival (2005 - present) and the "classic" series (1963 - 89). For convenience, I'll skip those likenesses that have already been offered, though using other base figures. Those would include Clara Oswald and Amy Pond by Qaz, Martha Jones (maker IDK) and Rose Tyler (Beth Capsces). Romana I, Leela and Sarah Jane Smith from BluBeetle.
Might as well mention the currently most important, Jodie Whittaker, playing the title character of the Doctor.
Mandip Gill as Yasmin Khan (who'll be returning)
Pearl Mackie who played Bill Potts.
River Song played by Alex Kingston.
Catherine Tate who played Donna Noble.
Backing into the "classic" run...
"Ace" Doroth McShane (Sophie Aldred) the last on screen companion of the 7th.
"Mel" Bush (Bonnie Langford), just to be fair.
Nicola Bryant as "Peri" Brown.
Nyssa (Sarah Sutton)
Tegan Jovanka (Janet Fielding)
Romana II (Lalla Ward)
Katy Manning as Jo Grant
Liz Shaw (Caroline John)
Zoe Heriot (Wendy Padbury) Someone had morphed her likeness ans shared the setting in a long dead thread years ago, but I doubt the file is still available.
Deborah Watling as Victoria Waterfield.
Polly (Anneke Willis) bridging the 1st and 2nd doctors.
"Dodo" Chaplet (Jackie Lane) I always thought they were trying to give us Susan 2.0.
Sara Kingdom (Jean Marsh) Her status as a "companion" is debated by passionate fans.
Katarine (Adrienne Hill)
Vicki (Maureen O'Brien) not to be confused with Victoria.
Barbara Wright (Jacqueline Hill) first human female (of which we know) who entered the TARDIS ...and finally...
Susan "Foreman" (Carole Ann Ford) The Doctor's granddaughter who, based upon available screen evidence, was the first traveling companion fleeing with the Doctor from Gallifrey.
Okay, that's a stupidly long list. Reducing it to the "most craved", I'd say Whittaker for the Doctor herself, Susan as she started the tradition with Barbara in a close running and Jo Grant because she's so tightly associated with Jon Pertwee's 3rd Doctor.
Sincerely,
Bill
Tempt the Hand of Fate and it'll give you the "finger"!
qaz ( ) posted Thu, 20 June 2019 at 11:26 AM
Redfern posted at 10:54AM Thu, 20 June 2019 - #4353595
Sincerely,
Bill
As you say I did Amy and Clara morphs, available at Sharecg. The lovely Zoe was an old figure that was a collaboration between myself and Cage, many years ago. She isn't bad considering her age. If you can find Cage and get his permission I will release her.
As far as the rest of the list.
Jodie Whittaker - not a chance. She and her politically correct buddies wrecked Dr Who. Romana I Mary Tamm - I had the hots for her as a child. She is definitely on my list. Nicola Bryant as "Peri" Brown - reference shots already there. Deborah Watling as Victoria Waterfield - one of the first pencil drawings I ever did was of her.
They are the ones with the best chance. Did you ever see the photo of a naked Katy Manning cuddling a Dalek ?
Redfern ( ) posted Thu, 20 June 2019 at 11:43 AM
Cage posted in the Poser new ownership thread earlier just this morning. (And yeah, it was Cage's offering that I was trying to remember.)
Okay, I won't say anymore about Whittaker, obviously a sensitive subject for some.
As for Katy Manning's infamous Dalek photoshoot, heh, heh, I suspect I have sizeable number of the different shots from that session. Not originals, mind you, just scans I've found online.
Sincerely,
Bill
qaz ( ) posted Thu, 20 June 2019 at 4:33 PM
Redfern posted at 4:10PM Thu, 20 June 2019 - #4353648
Sincerely,
Bill
Another few I'd like to do from old UK Sci Fi servallan - jacqueline pearce Deliciously evil. UFO - Gabrielle Drake and very like Wendy Padbury The first superheroine sharron macready - Alexandra Bastedo The first Avenger ? Emma Peel - Diana Rigg
However, I'm sure our American friends are going who ?? So this is more a popularity contest
Nod ( ) posted Thu, 20 June 2019 at 5:09 PM
Looks very good indeed.
qaz posted at 11:08PM Thu, 20 June 2019 - #4353193
Latest iteration
Nod ( ) posted Thu, 20 June 2019 at 5:10 PM
Lovely. rokket posted at 11:10PM Thu, 20 June 2019 - #4353377
Nod ( ) posted Thu, 20 June 2019 at 5:16 PM
Looks just like Wendy. Other than that, I used to live not far from Mary Tamm. She used to say hello to me if I was cutting my hedge and she was passing. ?
qaz posted at 11:15PM Thu, 20 June 2019 - #4353643
Sincerely,
Bill
rokket ( ) posted Thu, 20 June 2019 at 5:18 PM
I have my own Wonder Woman body done. I am still working on the Lynda Carter body morph, but that should be completed soon. I still have to tweak the face on this one a bit... WW Body.png
qaz ( ) posted Thu, 20 June 2019 at 5:34 PM
Nod posted at 5:31PM Thu, 20 June 2019 - #4353744
A very beautiful woman. A great tragedy she died so young.
Nod ( ) posted Thu, 20 June 2019 at 5:54 PM ยท edited Thu, 20 June 2019 at 5:55 PM
I did say at the start of this that I'd love a Lena Headey morph.
Other than that Actresses and celebs....
Sarah Michelle Gellar
Jenna Coleman
Cate Blanchett
Raquel Welch
Debbie Harry
Anna Torv
Kylie
Karen Gillan
Kelly MacDonald
Rose Leslie
Shirley Manson
Kate Dickie
Pollyanna McIntosh
Deborah Kerr
Audrey Hepburn
Britt Ekland
Caroline Munro
Ingrid Pitt
Jamie Lee Curtis
Valerie Leon
Carrie Fisher
You can see I jump between sci-fi and scream queens, with some singers thrown in. ?
Nod ( ) posted Thu, 20 June 2019 at 6:15 PM
There's a good LaFemme morph of Emilia Clarke by Tempesta3d. Mind you, the eyebrows seem way too bushy though.
qaz ( ) posted Thu, 20 June 2019 at 8:01 PM
Nod posted at 7:44PM Thu, 20 June 2019 - #4353766
Good find ! Tempesta's strength is in her textures, and for a second I thought those eyebrows were Emilia's actual brows. Emilia does have bushy brows and thicker even , but not as straggly as the ones Tempesta has used .However Daenerys does not. The actress has the width and height reduced for her part. In some episodes it is even a different color. So that's Drakayna La Femme at Renderosity.
Here is one I did for V4. Not so bushy.
rokket ( ) posted Thu, 20 June 2019 at 9:17 PM
Dang, that looks just like her...
rokket ( ) posted Fri, 21 June 2019 at 8:03 AM ยท edited Fri, 21 June 2019 at 8:05 AM
LaFemme face morphs.
Even though it's not a celebrity morph, it just shows what you can do with her, using mainly her built in dials and qaz's Ulrika morph that I was beta testing for him.
Redfern ( ) posted Fri, 21 June 2019 at 8:16 AM
Qaz, I will understand if you'd prefer a public post directly from Cage, but I exchanged a few "site mails" with him last night and he granted his permission for the "Zoe" morph.
Sincerely,
Bill
qaz ( ) posted Fri, 21 June 2019 at 1:22 PM
digitell posted at 1:20PM Fri, 21 June 2019 - #4352279
qaz posted at 2:51PM Sat, 25 May 2019 - #4352267
There is a celeb morph in the rendo market place. See if you can find her. I have been working on a base figure (Ulrika) for La Femme. As a proof of concept, I have just finished a morph of a real person using Ulrika as a base. She is out there in the poserverse at the moment. I will post a picture next week.
What characters would people want ? If there is already a decent V4 version, there doesn't seem much point creating a La Femme version.
If someone could make the character Stahma Tarr from the Show Defiance, I would LOVE it! I have been looking but not found her as of yet. The actress name is Jamie Murray. I would need to find a texture to go with the morph tho...very pale! StahmaTarr.jpeg
Just to say I did have a quick go at this, so at some point I do hope to release the character.
rokket ( ) posted Fri, 21 June 2019 at 3:59 PM
WW face WIP.png Finally done with this one. I don't know how to do inj/rem poses or I'd release it.
qaz ( ) posted Fri, 21 June 2019 at 4:09 PM
rokket posted at 4:01PM Fri, 21 June 2019 - #4353982
She is lovely. Unfortunately, because you have used Ulrika and I think BH HD morphs you can't. It has to be all your own work. That's why we had to get Cage's permission for me to release the Zoe morph to Redfern in the thread above. Although it has got my work in it, it also has someone elses.
rokket ( ) posted Fri, 21 June 2019 at 4:19 PM ยท edited Fri, 21 June 2019 at 4:20 PM
I didn't use any of Blackhearted's morphs, only Ulrika 5. I tried to stay away from using those or Deecey's morphs and just see what I could get out of her without those. Unfortunately, as you said, I had to use your morph to get her over that hump.
rokket ( ) posted Fri, 21 June 2019 at 4:21 PM
I used everything I had on the other face I am creating to become my Wonder Woman. And I am still not happy with it. Not completely.
Nod ( ) posted Fri, 21 June 2019 at 6:52 PM
That one is really good. You can tell who it is right away. The Tempesta3d ones also seem fuzzy, like they're a lower res.
qaz posted at 12:51AM Sat, 22 June 2019 - #4353801
rokket ( ) posted Fri, 21 June 2019 at 8:18 PM
I think I finally have the Wonder Woman I have been working toward. My other morph is cute, but she isn't Wonder Woman to me. This one is close.
qaz ( ) posted Fri, 21 June 2019 at 8:25 PM
Nod posted at 8:23PM Fri, 21 June 2019 - #4354015
Thanks Nod
Digitell ( ) posted Fri, 27 September 2019 at 4:02 PM
Forum Coordinator
Just saw this post! Looks very good to me! Thank you for working on it! I look forward to when you release her! :) qaz posted at 4:01PM Fri, 27 September 2019 - #4353948
FleetR ( ) posted Sun, 29 September 2019 at 4:57 PM
Cara Delevingne from Carnival Row (and other things.).
  • 1
  • 2
