Fri, Dec 13, 1:04 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Dec 08 9:10 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Tiled Textures
madmitch ( ) posted Sat, 22 June 2019 at 9:18 AM · edited Thu, 14 November 2024 at 7:51 PM
Is the a means in the cycles render to repeat an image based texture as per the horizontal and vertical slide functions in Daz Studio
LuxXeon ( ) posted Sat, 22 June 2019 at 12:10 PM · edited Sat, 22 June 2019 at 12:11 PM
In the shader nodes, attach a Mapping node to the material maps you wish to tile, then you can adjust the scale parameter for XYZ. Alternatively, if the object is UV mapped, you could enter the UV Editing mode, select the UV islands and scale them larger or smaller. As long as your texture map is tileable, then it will repeat itself on the object as the UVs increase in size. The easiest way is just to attach a Mapping node and adjust the scale there. This gives you more control over the mapping.
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
madmitch ( ) posted Sun, 23 June 2019 at 6:28 AM
Works fine; many thanks
