Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 11:57 pm)
It is automatically animated if you make a movie instead of a still image.
Chuffing hell, that's superb, BB. Thanks very much for sharing it.
I have a picture in my mind of - you guessed it - burning Daleks. :)
Thee is this. I'm not sure if it fits exactly what you need but take a look. http://www.daz3d.com/smoke-and-flames-tool
___
Renderosity Store Personal nick:
Conniekat8
Hi, my name is "No, Bad Kitteh, NOO",
what's yours?
Yes, I will too, but I'm also needing just a single flame that I can us in a similar manner as BB demonstrated.
Also, how do I install the Fire.mt5.txt file? Do I need to change the extension?
For stills or animation ya could just put the flames in the renders or add them in post.
For a still ya could just paint it in post.
For anamtions app's like after effects.
I'm sure there' more then a few CGI flames app's out there.
Blender can make Flames.
The
Artist that will fight for decades to conquer their media.
Quote - Not looking for animation. Just need to be able to render a 3d representation of a single flame spiraling upward.
Easyiest fastest way would be after you rendered ya Poser render.
Send it to a 2D App & paint the flame in.
Gimps a very good Free 2D App.
The
Dumb question:
How do I install and apply the Fire.mt5.txt file BB posted above? Do I need to change the extension to something else besides a txt file?
Remove the txt extention and place into your Materials folder. From there you can apply the shader to an object. I have a folder inside of my Materials Folder completely dedicated to BB's shaders.
Weapons of choice:
just delete the ".txt" and try "Fire.mt5"
if "Fire.mt5" don't work change the .txt to what ever extensions are in the Materials folder.
there are .mt5's in the Materials folder.
The
Thank you, that worked. Much appreciative of the help.
Now big question: How do I make my own material? Is there a tutorial on how to make a material I can then apply to a shape? I'm needing to have a different flame pattern.
Also, when I apply BB's flame to a sphere it covers the bottom half. How do I get it to cover the whole sphere?
Here I modified the material to remove the modulation that was based on surface normal pointing up or down. This version will produce flames over the entire object you use it on. This will look less like a natural fire, but since you asked for it, here it is.
A single flame versus a fire - obviously these are related but they are so different that this shader simply does not apply.
Are you trying to use a BB orb because it is small? The fire material in this thread will
"apply" but is likely to not make sense. The random flames and gaps it produces are larger than the orb - it is likely that the orb falls entirely in a gap and becomes invisible, or is entirely filled with yellow and looks nothing like a flame.
If you supply a flame prop, I may be able to produce a suitable material for it. But nothing is going to make a sphere look like a flame.
Well, I was just trying out your orb to see if it would produce a better ball of fire.
What I am looking for is a spiraling flame, something similar to:
http://www.flagstaffhearthandhome.com/images/homepage/torch2-581pix.jpg
or
http://www.loupiote.com/photos/31017504.shtml
or like this candle shape, but as a flame:
http://img1.etsystatic.com/022/1/7449142/il_570xN.486584027_5ytw.jpg
Stumbled on this thread looking for pointers on fire - BB's shaders look fantastic but the links appear to be dead. Any hope of getting them relinked, or a screenshot of the setup?
The New HD Toaster from Wamco toasts bread more evenly and acurately than Standard Toasters. Take advantage of the FULL resolution of your bread and try one today, because if your toast isn't in High Definition, you are not getting the most of your toast!
@thekageRyu - You can get a BB fire shader from his Google site in the file cabinet area BB's stuff . It is for Firefly, not Superfly.
For P11 using Superfly, seachnasaigh has a material pack with a fire shader in the freestuff here
@raven - I had already checked there and I just checked again and the fire shader does not seem to be there. I realise it is for FF, that is what I am looking for.
@willyb53 thank you, I think I have that somewhere, but I am really just in need of a high end material. I have been trying to make one myself, but could use ideas, when I saw the BB posts earlier I thought those looked perfect, and animatable (which would really be handy). I am retexturing several objects/figures for a project.
@raven - Thank you, I did not look under file cabinet I was looking under free stuff. I see it now, and I appreciate the pointer to it. I am sorry I missed it earlier.
I need to create flames in Poser 9 and I need to have them so I can manipulate their shape so that if I wanted to have a flaming spiral I can do it.
Is there a tutorial on how to do this?
