Fri, Jan 31, 2:59 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 30 6:38 pm)
Subject: new install
goofygrape ( ) posted Sat, 06 July 2019 at 12:29 AM · edited Fri, 31 January 2025 at 12:22 AM
1 were do the downloads go?Under public downloads? User /name/ app data .I forgot how to turn on the app data in this area. I want to install Studio in a external drive also the my library not on the C:/ drive. questions and sloppy spelling due to stress, big quake here 20 miles north of this house,7.4 3 hours ago,then 4.0 and 2.5's on and off every 45 seconds tell 10:30 pm Pacific time. quite a ordeal 😅 :{ Thank You goofygrape
goofygrape ( ) posted Sat, 06 July 2019 at 1:59 AM
Ok you guy's I found the app data folder and my files,now on to the business at hand the install problem.
FlagonsWorkshop ( ) posted Sat, 06 July 2019 at 3:26 PM
Honestly, unless you are only going to dabble, you don't want your data folders on your c:/, they get huge. I'm at the point I have over 2 TB of content. Fortunately you don't need to put it there. The DIM and Daz Studio both need to be on your C:/, none of the content does though. If you are using the Download Installation Manager you can set both the download directory and the install path to be on any drive you want. Then you need to Point Daz Studio to the same place. Keep in mind if you use an external drive, 1) it has to be connected when you are using DAZ Studio (comes under the heading of "No Duh") but also those things spin down when not in use, and they some times take some time to spin back up again. This can cause delays when you first access your library after a period of doing something else. It's minor but it can be irritating at times.
goofygrape ( ) posted Sat, 06 July 2019 at 9:35 PM · edited Sat, 06 July 2019 at 9:37 PM
Thank"s My temp C:/ is only 120 gb,less then 100 gb left. the old needing to be mess with 8 tb has 5 tb of daz / poser info,I di not download daz studio using dim because of the size ,now if I test the size of Studio maybe it can go on the ssd drive as a temp unit. Thank You FlagonsWorkshop PS. I do not dabble as much as sell stuff for games :) or free stuff.😆
