Mon, Feb 3, 12:07 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: Resetting a model to zero (not simly zeroing dials)
AcePyx ( ) posted Mon, 29 July 2019 at 5:41 AM ยท edited Sun, 02 February 2025 at 9:42 PM
I have a model that measures say 4 feet in the Poser world but I want it at 2 feet. All of my morphs are also created at 4 feet. If I load the figure at a scale of 50% when I apply the morphs, they will all scale it back up to 4 feet. If I load the model at 100%, then load all the morphs, then simply scale it down using the scale dial and save that, the model will now load into the scene correctly but the dials will now say 50% scale which is fine for me but rubbish for distribution.
Is there a way to either reset the dials so that the 50% size is now 100%? Alternately, is there a way to load the morphs at a smaller scale without manually having to scale them in another program first? As a last resort, does anyone know of a way to simply redefine the size of OBJs without retopologising them? I'm trying to do so in 3DS Max and every time I do, the model reports back the wrong number of vertices when I try to add the morphs.
Thanks in advance.
adp001 ( ) posted Mon, 29 July 2019 at 12:31 PM
Simplest way to get a scaled object:
  1. export wavefront obj from Poser
  2. import the same file back into Poser, but reduce the scale in Posers import dialog to your liking ๐Ÿ˜ƒ
AcePyx ( ) posted Fri, 02 August 2019 at 6:49 AM
Thanks very much adp - that did the trick!
adp001 posted at 12:49PM Fri, 02 August 2019 - #4358292
