Sat, Jan 25, 12:52 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 25 9:50 am)
banner
Subject: What files are essential for Poser Pro 11?
uncle808us ( ) posted Tue, 27 August 2019 at 12:20 PM · edited Sat, 25 January 2025 at 11:57 AM
There are a lot of files in the download manager are the all necessary to run Poser pro 11? Do I have to download them all? Trying to save space on my old computer. Thanks
MacBook Pro OSX El Capitan Ver 10.11.6
jennblake ( ) posted Tue, 27 August 2019 at 2:38 PM
Hi.
You are only required to install the Poser.exe and the support files. You will need the human figures ONLY as you want. And if you use the faceroom you will need at least one of those installed. But they are not required. 😄
uncle808us ( ) posted Tue, 27 August 2019 at 4:06 PM
jennblake posted at 5:04PM Tue, 27 August 2019 - #4360565
Hi.
You are only required to install the Poser.exe and the support files. You will need the human figures ONLY as you want. And if you use the faceroom you will need at least one of those installed. But they are not required. 😄 Thanks I ‘m on a Mac so I don’t think there is a.exe file. But what do yo mean by “the support files.” Thank you
jennblake ( ) posted Tue, 27 August 2019 at 4:41 PM
On the download manager..when you have the list of files to download and install you should see Poser and down in the list you should see Poser Support Files. Those should also be installed.
uncle808us ( ) posted Tue, 27 August 2019 at 10:26 PM
Got it installed and it's all working. Thank you.
jennblake ( ) posted Wed, 28 August 2019 at 9:02 AM
Welcome. 😄
ypvs ( ) posted Wed, 28 August 2019 at 6:51 PM
If room is very tight then you can get away with installing only the main Poser file. A downside is the User Manual PDF is in the support files. You cannot add them in isolation you must re-install Poser at the same time. I've not found a download for the P11 manual PDF- can this be made available here (serial number required)?
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
