Forum Moderators: tim, msansing, ebasham
MarketPlace Customers F.A.Q (Last Updated: 2024 Sep 18 11:03 pm)
Contact and Support Information:
To reach our Marketplace staff, please open a support ticket at
support.renderosity.com
Our goal is to respond to support tickets within 24 hours, 7 days a week.
Since the description has inaccurate information is it possible for you to just revert it to a previous version. I figure since it is your platform and it is a type of false advertising then doing something to make it accurate is within the scope of what you can do. Also I do suggest you don't take my word on it and test it out yourself to confirm that it in fact does not work.
Update I was contacted last night by lola69. It seems there was another way to use this. There is the Script which does not work with G8 but is the only thing indicated in the description or the documentation. There is also the pane that is added in by the plugin and is not noted down in any literature. I have tested it and confirmed it does work. I have also informed lola69 that the email they have on file with you is bouncing back so they should update that to prevent confusion in the future.
TheWeezel posted at 2:06PM Sat, 27 July 2019 - #4357971
@TheWeezel - I also bought the script but am away on holiday and cannot test it. Would it be possible to add a screenshot to show what you mean by the undocumented pane and what you did to get this to work. I've been following a thread elsewhere with a user pretty upset that the product doesn't work (described as "useless").
marble posted at 11:29AM Sat, 27 July 2019 - #4358138
You do need to install the plugin in the Plugins folder in the Daz studio application directory. Once you have that and startup you should have the option
When when you click it will bring up
That does seem to work with the G8F. At least it did for me on the one I tested. Sadly the current model I am working with really doesn't need it being rather small up top.
Well if you look back it does look like the email that was on file for lola69 was being bounced back so possibly with that and the lack of info on the BreastJig pane Rendo disabled the account until they had things updated. lola69 had contacted me and I did let them know about the email issue that Rendo had so hopefully that can get fixed.
Were you able to follow my instructions in my post at 11:32AM Sat, 27 July 2019 and get it working.
ruscular3d posted at 8:45AM Tue, 27 July 2021 - #4423972
I downloaded the new script that says gf8 would work on a new system fresh loaded and I still cant get it to work on GF8 but still works great on the other figure. I was using version 2.2 with DAZ 4.11
Look in Panes ( Tabs ) if you see that it doesn't work on G8F I wrote more briefly ... but if you can't handle it , write here and I'll explain better ...
Last week I purchased the BreastJig Script by lola69 (https://www.renderosity.com/mod/bcs/breastjig-script-for-dazstudio/111905/) to try and get breasts on my G8F models to look more natural. Reading through the description it does say that it works with G8F in the "Base Figures" section. however when I try to use the script on a G8F figure I get the following error.
I have tried to send 3 messages through sitemail to lola69 to get this resolved as I think that they may have updated the plugin but accidentally included an older version of the script when uploading it. How can I get this resolved? I would prefer to get a working script as I really want this to work but failing that if the script does not work with the G8F how can we get the incorrect description fixed so someone else is not buying the script for a product it doesn't work with?
