Wed, Feb 19, 4:30 PM CST
Forum Moderators: RedPhantom
Subject: La Femme export
knyghtmare2021 ( ) posted Tue, 03 September 2019 at 11:27 AM · edited Tue, 18 February 2025 at 5:30 AM
Ive tried a couple of times now to export La Femme's had to zBrush. Poser fails to export an .obj. What am I doing wrong? Is this a 'feature' so to speak? I can use the morph brush if need be, but zbrush has more options....
Boni ( ) posted Tue, 03 September 2019 at 1:31 PM
You may be able to export as a figure easier. Menu>figure>export figure mesh to GoZ With the way PP11 uses morphs etc. with the newer figures and the morphs integrated with the body rather than just individual body parts as with La Femme this is more likely to work. Have you set up Zbrush to know where your Poser .exe is? There are steps to be taken first. If you already know all this, my apologies.
Boni
knyghtmare2021 ( ) posted Tue, 03 September 2019 at 2:25 PM
No Boni, I have not. Please, elucidate :-D
CHK2033 ( ) posted Tue, 03 September 2019 at 3:27 PM · edited Tue, 03 September 2019 at 3:28 PM
In Zbrush, Preference/GoZ/path to Poser.
HP Zbook 17 G6,  intel Xeon  64 GB of ram 1 TB SSD, Quadro RTX 5000
knyghtmare2021 ( ) posted Tue, 03 September 2019 at 3:48 PM
CHK2033 posted at 3:48PM Tue, 03 September 2019 - #4361121
Thanks. I'll give it a try. Hopefully I can get it to work and start actually using La Femme
Boni ( ) posted Tue, 03 September 2019 at 6:09 PM
Please feel free to ask as many questions as you like. We will walk you through this as much as you need.
Boni
meatSim ( ) posted Tue, 03 September 2019 at 9:47 PM
Wow somebody's got his bitter pants on
tonyvilters posted at 9:46PM Tue, 03 September 2019 - #4361115
To export tubes, you need a plumber.
if rendersoty had had beta testers, that thing would never have been released. Now they are asking for early adopters.
The gang, has no clue what they are doing.
knyghtmare2021 ( ) posted Wed, 04 September 2019 at 4:12 AM
So I got zbrush pointed to Poser... how do i point poser to zbrush?
knyghtmare2021 ( ) posted Wed, 04 September 2019 at 4:17 AM · edited Wed, 04 September 2019 at 4:19 AM
Poser gives this error: CUsers]PublicPixologicGoZBrushGoZMakeObjectPath.exe failed (error 2: the system cannot find the file specified)
Edit, well thats because MakeObjectPath.exe doesn't exist -_-
caisson ( ) posted Wed, 04 September 2019 at 5:24 AM
There should be a folder called Poser in C:UsersPublicPixologicGoZApps; there should be 4 files in it, 3 text files called GoZ_Config, GoZ_Info and Instructions, plus a batch file called GoZBrushToPoser.
If they're not there, try reinstalling the separate Poser Support Files installer and they should then show up. I've had to do this on a few occasions myself.
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
Boni ( ) posted Wed, 04 September 2019 at 6:30 AM · edited Wed, 04 September 2019 at 6:34 AM
knyghtmare2021, if you don't have this (blocked in red) listed in Poser, then caisson's advice is your next step. IF you do have this, then that is where you send your La Femme TO Zbrush, first ... it will trigger ZBrush to open and then you follow the retrieve process.
Boni
knyghtmare2021 ( ) posted Wed, 04 September 2019 at 7:17 AM
caisson posted at 7:16AM Wed, 04 September 2019 - #4361170
So I'm at work now... but the folder does contain 4 files. I didn't check the file extensions this morning, but I can confirm they all LOOKED like text files....
caisson ( ) posted Wed, 04 September 2019 at 10:29 AM
I've had the same issue today following complete reinstall of Poser. Same error message, GoZMakeObjectPath.exe not found.
To fix it I went to Program Files-Pixologic-Zbrush 2019-Troubleshoot Help and reinstalled the separate GoZ installer. Then launched Zbrush, went to Preferences-GoZ and clicked on path to Poser. Waited for it to not find Poser, pointed it manually, then launched Poser and sent Andy2 to Zbrush using Export Figure Mesh to GoZ from the Figure menu. Success!
So, GoZMakeObjectPath.exe is installed by Pixologic's GoZ installer to Users-Public-Pixologic-GoZBrush, along with a bunch of other files and a Scripts folder.
Happy days are here again ;)
ghostship2 ( ) posted Wed, 04 September 2019 at 10:43 AM
please forgive my stupidity here. Couldn't you just open up the folder with her geometry file and copy that into another folder? Work on the copy of the file then import that back into Poser?
CHK2033 ( ) posted Wed, 04 September 2019 at 11:15 AM
knyghtmare2021 posted at 11:09AM Wed, 04 September 2019 - #4361172
Did you uninstall an older version of Poser which was linked to Zbrush,? Were you at any time even able to use the GoZ feature in Zbrush with any version of Poser ? This happen once a while back because I was using 2014 and removed it from the workstation,(kept poser pro 11) I just reinstalled the Poser support files from pro 11 in the download manager, (which contains the Goz files) and that fixed it.
caisson ( ) posted Wed, 04 September 2019 at 11:34 AM
@ghostship2 - using GoZ means you can choose to sculpt on the posed mesh, with polygroups by material or by body part, plus the ability to work on higher subD levels which you can choose to bake to lower levels or not ... lots of flexibility with a few button clicks. Reverse deformations is the correct term I think, and multi-resolution morphs.
@CHK2033 - the error message says that it's the Pixologic support file that is missing, so reinstalling GoZ should fix it.
knyghtmare2021 ( ) posted Wed, 04 September 2019 at 12:01 PM
ghostship2 posted at 11:09AM Wed, 04 September 2019 - #4361187
I can and I have lol. I just wanted to export JUST the face lol
CHK2033 ( ) posted Wed, 04 September 2019 at 12:54 PM
Ah missed that part, but I see now only the face/head is whats wanting to be exported,GoZ isnt really needed for that anyway. Just did it, hid the body handles/went down to SubD 0 in figures property tab, exported just the head as an OBJ. with only name in polygroups selected. imported obj in zbrush made a crease across la femmes head exported in Poser went to objects/load morph targets selected head and now LaFemme has a nice random line I created in Zbrush across her head.So actually kind confused now as to why originally that method didnt export an OBJ. Maybe the SubD or Handles thing ?
ghostman ( ) posted Wed, 04 September 2019 at 12:55 PM · edited Wed, 04 September 2019 at 12:55 PM
Everything is just so much smoother, faster and easier if Goz works the way it should. I would hate to be without it now that i've gotten too used with it.
"Dream like you'll live forever. Live like you'll die tomorrow."
Join PoserLounge Chat
knyghtmare2021 ( ) posted Wed, 04 September 2019 at 3:11 PM
CHK2033 posted at 3:11PM Wed, 04 September 2019 - #4361205
I'll try that!
knyghtmare2021 ( ) posted Thu, 05 September 2019 at 4:17 AM
It worked. I'm not sure what the issue was, but issue solved.
CHK2033 ( ) posted Thu, 05 September 2019 at 8:56 AM
Great, glad you got it done.
