Thu, Feb 6, 2:31 PM CST
Forum Moderators: nerd
Poser 11 / Poser Pro 11 OFFICIAL Technical F.A.Q (Last Updated: 2025 Jan 26 5:56 am)
banner
Subject: Lost my thumbs for older Poser content libraries content
shante ( ) posted Wed, 11 September 2019 at 11:24 AM · edited Thu, 06 February 2025 at 12:27 PM
I have been migrating Poser content since version 4 into Runtime Folders for use in now version 11. At each migration I seem to consistently lose the thumbs for the content in the Runtime folders. Makes it hard to see what you are finding or trying to load into a scene. I know I can just go down my Library folders add a file with a missing thumb into the scene and then reenter it into the library thus creating a new thumb. But I read some Poser versions back there was an easier way of creating those darn disappeared thumb images but can not find where I read it. Anyone here know of what I speak or does anyone know that easy way of creating thumbs for Poser content in Poser 11?
HartyBart ( ) posted Wed, 11 September 2019 at 12:54 PM
Before I re-index the runtime with PzDB I always use the free Poser RSR Converter. It's on Renderosity Freestuff as "RSR to PNG Converter".
Rhia474 ( ) posted Wed, 11 September 2019 at 1:04 PM
I second the RSR Converter recommendation above.
https://www.renderosity.com/mod/freestuff/rsr-to-png-converter/57197
Miss B ( ) posted Wed, 11 September 2019 at 1:19 PM
I'll third that recommend, as I've always found it came in handy with older purchases.
_______________
Butterfly Dezignz
ThunderStone ( ) posted Wed, 11 September 2019 at 1:38 PM
I'll fourth the recommendation. For all older contents from poser 3 and upwards, RSR converter is a must!
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
shante ( ) posted Wed, 11 September 2019 at 4:52 PM
does it work on a Mac?
ThunderStone ( ) posted Wed, 11 September 2019 at 5:15 PM
There should be a version that will work on a Mac. Google for RSR converter for Mac
Rhia474 ( ) posted Wed, 11 September 2019 at 6:16 PM
https://macdownload.informer.com/advice/Rsr_Converter.html
shante ( ) posted Thu, 12 September 2019 at 9:34 AM
Yeah got it. Now to figure out how it works. thanks to all for the help.
ypvs ( ) posted Sun, 15 September 2019 at 5:45 PM
If it's the same as the Windows version then its a simple as
Choose RSR folder- navigate to the folder to you want to start with, can be Runtime/libraries or single folder Select Recursive tick box- all sub-folders will also be converted. Convert- watch the activity in the box below
Once you're sure you've done all the folders then delete the RSR files
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Windows 7 64 bit, Avast AV, Comodo Firewall
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
shante ( ) posted Mon, 16 September 2019 at 1:44 AM
I was looking through my Runtime folders and I have a sheitz-load to create.....be there converting all darn day one at a time? Does this app do batch conversions?
ypvs ( ) posted Mon, 16 September 2019 at 4:05 AM
It doesn't appear to but does work quite quickly in the background and you can still work with Poser. As I said above, if you start in one of your runtime/ libraries folders and use recursive it will work through Characters, Props etc and all the sub-folders inside
hborre ( ) posted Mon, 16 September 2019 at 8:29 AM
The best RSR converter I've used is Dimension 3D's Runtime ZIP & Repair. Not only does it convert the RSR's to PNG's, but it also deletes them afterward. I just don't know if it works on the MAC system. Be aware, some very old content have made use of RSR's to store data. Those will not convert and will cause the program to quit prematurely. IIRC, there is an RSR file in the core Poser folder that shouldn't be touched.
shante ( ) posted Mon, 16 September 2019 at 12:47 PM
ok will look into ll this lots to process. thanks all.
