Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 19 2:30 am)
https://www.posersoftware.com/article/428/why-you-should-update-to-poser-112-on-sept-19?fbclid=IwAR22WbIbUHZuReIJYxdO2fRslBG_sq1UisMxqE_59e6acw5_GMcuxQqUh8w
Please read that article, it should answer most of your questions. It is as official as it gets, and the team was getting out information on a regular basis while early adopters were testing in the form of articles on that site and also linking on the Rendo facebook.
Thank you very much, that's all I need to know on one single page. Rhia474 posted at 10:51AM Mon, 16 September 2019 - #4362114
...also, is there anything that identifies "new content" versus prior included content?
I customize my Runtimes, so running a bulk content installer would probably add a LOAD of duplicate stuff into my runtime, since it is not in the original default install location. In the past there was installers for PoserAnimals.exe, Posercartoons.exe, etc...will there be a PoserNew112Content.exe, or something? Any other way to know?
So, I sent my questions in as a support ticket on PoserSoftware.com. (not sure if this is the official support area) I did not see a way to create an account...and my old Smith Micro account info did not work. That being said, it did let me submit a ticket...but no email response that anyone received it? (and no way to check on it, since I don't have an account...was hoping submit would create one)
Has anyone used the support on that site? (PoserSoftware.com)
Probably would not be too concerned, many of those relate to things like removing all references to Smith Micro as they were found, spelling errors etc. There are daily updates for the testers containing the fixes for previously found problems.
Bill
I see this new announcement refers to the update coming on the 19th as being for PoserPro 11 with no reference at all to plain ol' Poser 11 users. Yes, I know standard Poser is being phased out but right now I cannot upgrade; does this mean no more Poser fixes for me at all and it stops working after Sept. 19? :confused Byrdie looks confused:
[Peels away corner of NDA tape over mouth to utter] I've just been given permission to post this Why you should update to Poser 11.2
The contents were sent to, I presume, all of the registered owners of Poser from the Smith Micro database.
If it does not clearly state that this is a free update for all registered Poser users, that is the understanding I was given. My apologies if that is in any way incorrect, but that is what I was led to believe.
Explicitly, @Byrdie, I think that the intention is every Poser 11 user, whether Pro or not will need to upgrade to the new version to keep using Poser when the SM licence servers go away. Nothing prior to Poser 11 will be affected. No cost has been mentioned for a standard to pro migration (other than the implicit bandwidth costs of your own internet connection, of course)
Verbosity: Profusely promulgating Graham's number epics of complete and utter verbiage by the metric monkey barrel.
To clarify: this installation REQUIRES an uninstall of previous versions. If you have Poser installed, the new version will uninstall it for you - but if you don't, don't bother installing the old one, go straight to the new installer.
Feel free to call me Ohki!
So if I understand the whole thing correctly .... there will not be a update ?! you have to uninstall Poser and reinstall the new full version. this might cause some little disasters for some users as having Pyton scripts and personal setups sorted and arranged all would get lost and one has to rearrange the whole Poser Preferences. hoping that there will be an option to keep the Preferences and Installed pyton scripts as for some it really might cause many hours of work rearranging it all just because it is a bridge release without any changes.
The second worry is .... does the activation path remain the same " C:ProgramDataPoser11 " as Poser 11 caused sometimes errors and after crashes the licence got corrupted so some users had to delete the Licence folder to be able to reactivate poser . this crash caused that Poser could not boot and is the only way to fix the Issue. If the Licence " Activation Path " has been changed it sure would be Important to know where the new Path will be after the Update.
It won't delete your entire Poser folder - pretty sure it will keep your python scripts in place. (I say "pretty sure" because somewhere along testing I manually deleted my Poser folder to make sure I was testing the correct stuff, so I lost my scripts because of that.) In worst case, you can copy your entire Python folder somewhere else before installing, run the installer and then paste the Python folder over, telling it to not replace files that are already there (so that you keep possible new versions of base Python scripts)
And your preferences will be kept if, during installation, you ask the installer to use the existing preferences.There are the usual options to delete, backup (default option) or use existing preferences - just make sure not to skip through this option during installation.
This is the same as some other updates we've had for Poser before - the installer itself will uninstall, then install the new version.
I don't have an answer to your second worry - I've never had that problem.
Afrodite-Ohki posted at 7:14PM Tue, 17 September 2019 - #4362333
That's exactly what I did yesterday, though what I did was just keep the addon scripts I installed like, for instance, all my Netherworks goodies. That way I can add them back without having to worry about reinstalling an old version of a default Poser Python script that's been updated.
_______________
Afrodite-Ohki posted at 7:45AM Wed, 18 September 2019 - #4362328
OK, that just sent my panic levels through the roof. I HATE updating programs that work perfectly fine right now. Why the hell does the whole thing need to be uninstalled.?
Do we need to back up stuff? If so, which stuff should we be backing up?
Thanks Rendo...you just shot my stress level sky high.
Doc000 posted at 10:07AM Wed, 18 September 2019 - #4362384
Because the program needs to change some things at base-level, and for that an update isn't enough. Remember that the very registration server is changing, and the old one will stop working - Rendo isn't to blame for this, SM is the one that instated the phone-home system for Poser 11.
The installer will ask you first if you want to uninstall the previous one, but if you refuse it will just shut down. Your old Poser 11 will stop working anyway because it won't be able to phone home - the "number" has changed, so to say.
I'm pretty sure the only thing you need to back up is your scripts folder - maybe your entire Runtime IF you don't use external runtimes (those will NOT be touched). If you want to protect yourself against a possibility of your own absent-mindedness, you can backup your preferences folder in case you forget to tell the installer to use previous preferences (but if you forget to use that option, the installer will backup your preferences anyway, so you CAN recover them later).
I'm running tests here. Mind you, I have both Poser and all my runtimes (including the default one) installed in a hard drive other than my Windows one, and it's advised not to use the Shared Documents folder for Runtime anyway, since forever, because possible bugs.
Process:
-Added EzSkin3 to Poser 11 folder (because I currently had no custom scripts installed so I added this for test).
-Added one of my La Femme products into Poser 11 Content folder (aka default runtime).
-Uninstalled (via Window's "Uninstall or Change a Program" window) Poser Early Adopter version which is what I was using.
-Installed SM's latest Poser Pro 11 version, remembering to chose "Use Existing Preference Files" when I'm prompted about that. Same installation folder - I:/Poser 11 for me - and default runtime folder - I:/Poser 11 Content for me.
-Ran the installer for current Poser 11.2 early adopter version. It didn't ask me if I wanted to uninstall the previous version, like it does when we install new versions of the early adopter program, for some reason, but it didn't prompt me for a Poser folder, which leads me to believe it's found the old installation correctly. Prompts me for a content folder however, which I'm pointing to the same folder I was using before (I:/Poser 11 Content in my case). Again, it asks if I want to backup existing preferences, I tell it to USE my existing preferences.
-Poser 11.2 loads with my preferences intact, my custom layout is there, my render presets are there. EzSkin is there. My product is correctly inside the default Content folder.
On the download page, the files there are dated last evening; are they 11.2?
"Oh - the manual says that? I have never read the manual - this must be why."All of the Early Adopter versions are 11.2 - and then some. The one that's currently there, posted 09-17-2019 10:09 pm, is 11.2.263
Afrodite-Ohki posted at 11:33AM Wed, 18 September 2019 - #4362407
Ok, so it's not the Gold Release. Thanx!
"Oh - the manual says that? I have never read the manual - this must be why."Afrodite-Ohki posted at 10:50AM Wed, 18 September 2019 - #4362396
OK, can someone clarify this for me, since everybody keeps mentioning it? I don't recall my Poser ever doing this "phone home" thing, unless it's so far in the background that I just don't notice it. In fact, I'm pretty sure I've used it a few times when my DSL was down, and I had no internet connection.
Just did the "early adopter" download to 11.2._______. This far, no issues. However, I didnt find the files for Dawn, Dusk, and the additional animals. Not that I'll be using them all that much anyway, but did I miss something? I was thinking about doing some Dusk textures.
Doc000 posted at 3:28PM Wed, 18 September 2019 - #4362412
From what I've seen others say about it, it's very much in the background, and it happens in set periods, not all of the time - so if you had your DSL down only sometimes you wouldn't notice it, but people working offline would. For those, they had to use that feature to permanently lock the license to a specific computer.
Also, this is a Poser 11 / Poser Pro 11 / Poser 2014 Game Dev only thing, previous versions didn't have it.
SeanMartin posted at 3:31PM Wed, 18 September 2019 - #4362425
From the downloads of last night (I didn't have the chance to check for new files today), they're not there yet. Which is understandable, as it seems like the release date was pushed for later specifically to have those added. We might only see them on the final, public release.
Afrodite-Ohki posted at 5:15PM Wed, 18 September 2019 - #4362436
There is stuff there now @ 5:15 pm. A bunch of files under the Common list and one for Windows and Mac. But are the windows files the content I already have with my old install of Poser?
Also the download for Poser is listed at 09-18-2019 12:09 pm, is that the final build or will there be one more for today?
Please understand that I'm just one of the early adopters and not a spokesperson.
What I mean is... I have no idea.
Thanks for all the info, I am beginning to see the light! One more question: does the "Uninstall your old Poser" direction refer to just our Poser 11/Poser Pro 11 versions or are other installs in danger of borking when we go to get the update? I have a Poser Pro 2014 -- NOT Game Developer edition -- that I would absolutely hate to lose.
Also, YOU won't need to uninstall any versions. If the Poser 11.2 installer needs to have the previous Poser 11 (or Poser Pro 2014 Game Dev?) uninstalled, it'll uninstall it itself, without needing you to manually uninstall anything.
Glad to know my PP 2014 is safe, have not gotten around to reinstalling my old Poser 11 after the last go-round of computer problems so I should be all set for the new update when it comes out. Are the serial numbers changing too or just the activation method? Got my P11 serial number from Smith Micro, have not heard from Bondware yet about a new one.
Your serial number is your serial number, that does not change. Unless you have the versions affected by the SM phone home activation system, there is no need to do anything. Poser 11 / Poser Pro 11 / Poser 2014 Game Dev only as it was stated above. If you have P11, I'd download the update since a. it upgrades your version to Pro if you didn't have it yet and b. it will switch your activation over to the Bondware servers.
movida posted at 7:51AM Thu, 19 September 2019 - #4362582
If you made your license "permanent" with SM you ddn't need to connect to their servers for continuous permission. I want my work machine to not be connected to the internet. What I'm asking is will the 11.2 update allow the machine to not phone home everytime you use it.
Ask Jenn Blake. Honestly, except for SM I haven't heard anything about whether Poser needs to remain on the internet since Bondware took over.
Hi there, maybe im a bit to early but today is September 16 and the anounced Update for Poser 11 is a no-show so far. Did i miss something? Is there a special place for the download? And how about a link to this place, perhabs on the frontpage of this website?
