Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 21 11:57 pm)
First, this question is more appropriate in the Poser forum or the Modelling one. Second, there is no EASY way to create clothing and props, but there are MANY tutorials on both, at every level of complexity you can think of, either on this site or out on the web; if you have a specific item you want to make, someone here should be able to at least point you in the direction of an appropriate tutorial.
you may want to lookinto the poser propack for mwking conforming clothing it is the easiest way that have found to make them, as for your 1st question...yes, ,just click on the cloth and then in your newfigures of the figures panel, click on the + sign and it ill ask you if you want to save the entire thing or jus the obj...select just the object, hen you can use it on another figure...I do it all the time.
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Hi, I am newie in Poser. I have 2 questions about clothing I hope you can help me: 1)I downloaded several models. I load someone and a figure has conformed cloth . Can I "take" the cloth and create a new figure in the library for use with another figure? 2) Is there some tutorial (easy) for create new cloth and props? Thanks a lot Leazo (sorry for my english)
