Mon, Jan 20, 10:37 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Subject: Here's a bit of Poser 11.2 weirdness...
SamTherapy ( ) posted Sat, 28 September 2019 at 10:43 AM ยท edited Mon, 20 January 2025 at 10:28 AM
... and one from before.
On the renders list at the side of the screen, as the unwanted renders pile up, I delete them. There are a few I keep there as quick reminders of stuff I'm working on, or things I want to go back to later. All the other stuff, though, I trash them before I close. Since the change to 11.2, though, not all the ones I delete stay deleted. Next time I open Poser, some - or all - are there again, large as life and twice as ugly. Odd.
T'other strange thing is, from time to time, if I "New" Poser, it will hang and eventually ask me to locate Black Texture.png. Never been able to find the chuffing thing, and seeing as it's not something that happens all the time, I tend to forget until the next time it happens. Any ideas what's causing it, and where this Black Texture.png is located, because I can't find the buggering thing.
I'm on Win 7 Pro if that's any help.
SamTherapy ( ) posted Sat, 28 September 2019 at 10:44 AM
I neglected to add, the Black Texture thing is the one that started happening before I changed over to 11.2.
caisson ( ) posted Sat, 28 September 2019 at 10:54 AM
I'm on Win10 and I can find BlackTexture.png in AppData/Roaming in my Users folder; it also shows up in Local/Temp/Poser/11. Absolutely no idea of what it's for, but I also see it as BlackTexture.png.exr in the PoserTextureCache temp folder.
Not approved by Scarfolk Council. For more information please reread. Or visit my local shop.
randym77 ( ) posted Sat, 28 September 2019 at 10:56 AM
SamTherapy posted at 10:51AM Sat, 28 September 2019 - #4364568
That happened to me, too! Also before the 11.2 update.
IIRC...it seemed to be connected to the ground plane. There was a loose node there called black.png. I deleted it, then saved it as the new default.
Nails60 ( ) posted Sat, 28 September 2019 at 11:09 AM
I believe that if you have something with a missing texture poser creates blacktexture.png. And so a pz3 that was saved with this will include a reference to it, so poser looks for it. I can't remember where I read this so I could be confused about it, a usual state for me!
SamTherapy ( ) posted Sat, 28 September 2019 at 12:02 PM
Thanks for the info, people. Now to hunt for that chuffing texture. ๐Ÿ˜
structure ( ) posted Sat, 28 September 2019 at 1:07 PM ยท edited Sat, 28 September 2019 at 1:08 PM
Forum Coordinator
I made a copy of the blacktexture.png and saved it into the root folder of my poser textures - I found that the missing blacktexture seems to happen if you clear your temp folder while poser is running - anyway, copying it to runtime:textures made it easy to just point poser at it.
Locked Out
Miss B ( ) posted Sat, 28 September 2019 at 5:37 PM
Nails60 posted at 6:36PM Sat, 28 September 2019 - #4364574
Hmmmm, I wonder if that's something in the newest versions, as I've always just gotten call-outs for missing textures before.
_______________
Butterfly Dezignz
Miss B ( ) posted Sat, 28 September 2019 at 5:52 PM
randym77 posted at 6:44PM Sat, 28 September 2019 - #4364570
Hmmm, that's odd, as I've never seen that before. There is a "loose" node with a default graphic attached, but it's not the Black Texture. I've never seen that in any version of PP11 I've had installed.
_______________
Butterfly Dezignz
SamTherapy ( ) posted Sat, 28 September 2019 at 6:35 PM
Anyhow, seeing as the BlackTexture malarkey has been well and truly discussed, how about my other problem, "The Strange Case Of The Renders That Won't Die"?
Anyone else encountered this?
Nails60 ( ) posted Sat, 28 September 2019 at 6:40 PM
I have found that renders that I do in a session and then delete, don't delete. To get rid of them you have to close poser, re-open then delete
SamTherapy ( ) posted Sat, 28 September 2019 at 6:46 PM
Nails60 posted at 12:44AM Sun, 29 September 2019 - #4364663
Ah, but did this happen before you changed over to 11.2? I never had the problem before. I guess it's not a problem because at least you stand a chance of getting back something you accidentally deleted.
Nails60 ( ) posted Sun, 29 September 2019 at 3:02 PM
For me this started with poser 11
raven ( ) posted Sun, 29 September 2019 at 3:16 PM
Online Now!
That render cache problem started happening for me 3 years ago, I even posted about it in the SM forums in this post ๐Ÿ˜„ https://forum.smithmicro.com/topic/1557/poser-error-upon-start
SamTherapy ( ) posted Sun, 29 September 2019 at 5:27 PM
"Curiouser and curiouser," said Alice. And me. Never happened to me before now. Odder than a big bag of very odd things.
SeanMartin ( ) posted Sun, 29 September 2019 at 6:06 PM
I dont know if this makes any difference, but I closed that window when I set up my standard parameters.
structure ( ) posted Sun, 29 September 2019 at 7:56 PM ยท edited Sun, 29 September 2019 at 7:56 PM
Forum Coordinator
It appears that poser keeps any newly rendered files open even after you have finished with them. I have raised this as an issue for the devs attention. It appears atm that this is only a windows issue, and does not affect mac.
Locked Out
