Thu, Nov 28, 7:56 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Nov 24 8:44 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Blender 2.8 Tutorial - Abstract Geometric Sphere For 3d Print or Mograph
LuxXeon ( ) posted Thu, 17 October 2019 at 8:47 PM ยท edited Thu, 28 November 2024 at 7:35 PM
In this tutorial, we create an interesting spherical abstract shape that can be used in 3d printing or motion graphics design, using Blender 2.8 or higher. However, there's nothing here that couldn't be done in earlier versions of Blender, but obviously the hotkeys and shortcuts will be very different.
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook:ย https://www.facebook.com/luxxeon
Miss B ( ) posted Thu, 17 October 2019 at 8:53 PM
Ohhhh, that certainly looks interesting. I may just have to try it out.
BTW, I don't think I mentioned, but I tried the Merkaba tutorial and it came out nice. My only problem is it's so high poly, I'm having a problem getting it UV'd, but I'll persist. ๐Ÿ˜‰
_______________
Butterfly Dezignz
LuxXeon ( ) posted Fri, 18 October 2019 at 10:41 AM
Miss B posted at 10:38AM Fri, 18 October 2019 - #4367510
I think I have two tutorials for the Merkaba on my channel. Which one did you use? I didn't include a UV tut with my videos back then, but the trick is to UV unwrap the model while it's still low poly. In fact, I don't think you actually need to subdivide the merkaba at all unless you're going to 3d print the model and want to have soft edges. If you're just using it for rendering or motion graphics, you can just keep it low poly and use the bevel modifier to create rounded edges. Just unwrap the model while it's low poly (before you apply the subdivide modifier). The UV's will get subdivided with the modifier.
My Free Models
My Video Tutorials
My CG Animations
Miss B ( ) posted Fri, 18 October 2019 at 11:49 AM ยท edited Fri, 18 October 2019 at 11:50 AM
LuxXeon posted at 12:43PM Fri, 18 October 2019 - #4367547
I have the one you posted back on Dec. 29, 2015 for modeling the Merkaba in version 2.76 bookmarked, so that must be the one I tried. This is in Blender with Cycles, so not what I would call a "final" render. ๐Ÿ˜‰
_______________
Butterfly Dezignz
LuxXeon ( ) posted Fri, 18 October 2019 at 10:54 PM
That's looking really good, Miss B! Can't wait till you do the final render! There's a couple of options here. First, you can mark seams and do an unwrap on the low poly version just before adding the subdivision surface modifier as I mentioned, so probably at the stage it is in around the 19:32 mark of the video. Once you unwrap the low poly, you can add the subdivisions surfaces modifier and it should maintain the UVs. Another option, if you have already applied the Subdivision Surfaces modifier and don't have the option to unwrap low poly, is to simply add a UVW > Box mapping to the model for a very quick and dirty UV application. You could select and scale down the result in the UV editor after you create the box map. A Cube Projection map is similar to this and would also work as a dirty fix.
Looking back at that tutorial, I really need to update it for Blender 2.8. There are much easier methods I could add to an updated video which would have probably saved you a lot of time. You did a great job though, so no worries there.
My Free Models
My Video Tutorials
My CG Animations
LuxXeon ( ) posted Fri, 18 October 2019 at 11:04 PM
Here's some examples of how the Cube Projection mapping would turn out on a merkabah which had already been subdivided. It would apply very quickly without any previous UV seams.
It doesn't do a "perfect" job, and it does create overlapping UV islands, but as long as you don't need perfect UV boundaries for some reason, it will render and tile just fine as you can see below:
My Free Models
My Video Tutorials
My CG Animations
Miss B ( ) posted Sat, 19 October 2019 at 11:51 AM
Ohhhhh, very interesting indeed Lux. I'll definitely have to try that. Needless to say, next time I try it, I'll be unwrapping before subdividing. I should've realized that myself, but wasn't thinking in terms of uv mapping it while I was creating it. Oh well, lesson learned. ๐Ÿ˜‰
_______________
Butterfly Dezignz
LuxXeon ( ) posted Sat, 19 October 2019 at 1:42 PM
Miss B posted at 1:40PM Sat, 19 October 2019 - #4367649
That's my fault, Miss B. My older videos never addressed UV editing, unfortunately. I was always just focused on showing how to create manifold mesh for 3d printing (which often doesn't require UV coordinates), but I should have included that step. I apologize for neglecting that. My latest videos and all videos going forward will include some form of UV editing. Great work, Miss B. Please follow up with your final render too. Would love to see it.
My Free Models
My Video Tutorials
My CG Animations
Miss B ( ) posted Sat, 19 October 2019 at 4:35 PM
Oh, I will post it when I'm happy with the final render. ๐Ÿ™‚
_______________
Butterfly Dezignz
