Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 6:38 pm)
@eclark1894, it doesn't tell you if it goes before or after another node. It doesn't tell you which nodes work in conjunction of which other node. It took weeks to figure out how to add a tattoo to a figure without having to edit the original image. still trying to figure out how to add a tattoo to two overlapping images like part is on legs, and part is on hip and getting right.
Dive into Fantasy and Ride the Waves
I have many scenes in my head, but non of those are on paper.
I have yet to learn to bring those to life.
The ones that I give life, are not those I see
So you want documentation on what each node does individually, AND what each node will do if you plug into each other node and what they will do together? Yeah, good luck with that. I don't mean to sound flippant, but that seems more of an experimentation, trial by error type of thing. Even if you write it down, judging from how many people actually don't read the manual, no will ever read the documentation.
This comes directly from the Reference Manual and describes in one word, "infinite", why it would be "difficult" at best to write down all the interactions between nodes:
Material Room Node Connections The Advanced view of the Material room uses a plug system to connect nodes together. Node inputs typically appear on the right side of a node’s palette, and the node output typically appears in the upper-left corner of the node palette.
Node inputs and outputs. You can link nodes to other nodes, thereby controlling one node’s input with another node’s output. This interaction between nodes is at the heart of the Material room’s functionality and provides nearly infinite flexibility. Node interaction works by plugging values or colors from one node into another. Although only one node’s output can be connected to another node’s input at the same time, there is no theoretical limit to how deep these interactions can go. Available memory and CPU speed will play a role in setting practical limits.
Also, I can't speak intelligently on Firefly, as I never got to into it, but Cycles nodes tend to "gray out" to prevent you from plugging the wrong input to the node. I would assume Firefly does the same, but that's only an assumption at this point.
First would like to see the hair room fixed so that hair does not penetrate the model, Never have got it to work for animations which is frustrating. Even if use two stands, one will always penetrate the model, even if the scull cap is slightly away from model.
Next would like to see an easy way to send part of the figure to a program of my choice to morph. When I try, I get the message "No facet"
and last would like to see documentation as to what each and every node does so know how to use them to enhance renders
