Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 16 7:48 pm)
When it says it will delete your old version of poser, it is talking about the program itself.
I suggest you follow this path as you go through
Click OK
Click YES
Click NO
Backing up of settings or using new settings will follow the last screen
( alternatively : you can use this script to open the preferences folder ( if you do not know how to find it ) and back them up manually )
your content will not be deleted.
Locked Out
Gltterati3D is right on the money with that post, you need to Use Existing Settings. If you don't uninstall first, you run the risk of adding corrected content to questionable content that already exist. You will have an unholy mess on your hands trying to sort out bad and good content. Trust me, you'll be fine with the advice from above.
when I run the update I am told it will uninstall poser and it's content before installing the update, where is the option to backup my settings???? let alone is this going to effect my runtime? if it removes that i'm going to be really annoyed.
Getting old and still making "art" without soiling myself, now that's success.
