Thu, Nov 7, 2:36 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 07 12:47 pm)
Subject: sharper edge blend?
eyeteeth ( ) posted Thu, 17 October 2019 at 8:21 PM · edited Thu, 24 October 2024 at 4:33 AM
hello, is there a math function i can plug the attenuation into on Edge Blend in order to make the blend less diffuse? so there is a sharper divide between "outer" and "inner"? increasing attenuation value makes it sharper by shrinking the total inner area, i want to leave the overall balance between outer and inner the same but reduce the size of the area where they blend together.
ghostship2 ( ) posted Fri, 18 October 2019 at 4:06 PM
Fresnel blend might be better suited to what you are trying to do.
seachnasaigh ( ) posted Sat, 19 October 2019 at 7:37 AM · edited Sat, 19 October 2019 at 7:38 AM
You're wanting a steeper falloff for the edge_blend? Is this the effect you want? (Ignore the inner sphere, which is a separate prop):
This would do it; the power function (set to 5th power, in this case) will exaggerate the falloff; increasing the exponent will sharpen the falloff. Since it also greatly diminishes the entire range of values, I also multiply it to make it visible again. The two nodes below the color map are just a "tattletale" to let me know if I've exceeded 1 in value.
eyeteeth ( ) posted Mon, 21 October 2019 at 11:12 AM
seachnasaigh posted at 11:12AM Mon, 21 October 2019 - #4367620
wow thank you, i think this might do it!
