Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 7:16 pm)
Three other possibilities that occur to me offhand:
Is the display mode texture shaded? (Click the icon which looks like a billiard ball).
Check the render settings for the preview renderer. Enable hardware shading is important. Nerd3D's annotation:
Third possibility is that the material setup is complex, beyond what the preview renderer can interpret.
OSes: Win7Prox64, Win7Ultx64
Ah ha! Thanks, seachnasaigh, it's something in the Render Settings Preview tab. I now have textures showing on the construct like normal instead of the washed out white void that it was before. I'll have to play around with it and see what it actually is that's doing it :D
-edit-
It was the 'Enable hardware shading' option in the Preview tab that did it. It's odd because one would think that wouldn't affect textures, but oh well, as long as it's working properly, that's all I care about.
Oh, no, it's not surprising. Enable hardware shading makes major improvements in the preview renderer. Tiling does not show in preview unless you have hardware shading enabled, for example. Set offscreen handling to PBuffer if you have a decent graphics card. Definitely select OpenGL (not SreeD) if you have a capable GPU.
I'm sure this is an easy fix and I'm just missing something simple, but after (finally) installing the P11.2 update, I just cannot find the setting to change the construct dome to show the textures in preview mode. When I set everything up, I get this:
What I want it to look like is this:
The second one is actually from another project file and it shows the texture normally, but when I set up a new scene, it goes completely blank. I tried applying the texture to ensure it was there and I have changed all the display properties to Texture Shaded, but I think there was something else and I'm forgetting something.
"Help me, Poser Community, you're my only hope." - Not Princess Leia
